Question about Electric Cycling
I own a baby moto electric bicycle. after a acsident were the motoer took a realy hard hit, it as got stiff to turn.allso aloss of power & longevity. the moter is a 24v 10ha.can it be repaerd ifso at wot cost
I have a Bay Moto electric bike for sale for spares if that is any help
Posted on May 16, 2010
My cyclamatic bike hasnt been used for a while i charged the battery and it has a full charge but when i hit the on switch no power showing on the lights any ideas?
If the battery has charged and you confirmed this by testing the voltage, then it could be that the battery and/or switch has dirty contacts. Try cleaning the contacts or removing/refitting the battery a few times and turning the switch on/off a few times.
Jun 11, 2016 | Electric Bicycle Motor, Bike,electric...
Power steering stiff after recon steering turns pump works steering stay stiff and hard no power steering even if you start the engine
Check the drive belt to the power steering pump and the level of fluid in the power steering reservoir.
Feb 18, 2014 | 1996 Honda Prelude
2003 honda accord 2.4 power stering hard,replace pump got little softer but still hard
The steering is controlled by the steering rack,
& they get stiff because no one changes the fluid
every 3 years
The upper strut bearings fail & make steering stiff
Doubt the pump was a problem at all
Mar 03, 2013 | Cars & Trucks
No suction from my kirby sentria
I just took a stiff piece of coax cable, and took the bag off where it attaches to the main unit, and took the head off ( the part with the brush roll in it) AMD cleaned every thing really well, turning the spindle for the fan while " snaking" it and pulled out a baby sock! Ta-Da! Works like New.
Apr 29, 2012 | Kirby Ultimate G Bagged Upright Vacuum
@runs hot motor feels slow doesnt hit hard
Bosch brute is made to work all day every day and will continue to do so if it is not over or under powered and properly lubed. If not powered correctly, motor will not turn at full rpm, get very hot and burn brushes to point that auto stop feature will stop motor (brush will push away from armature, or burn switch). The hammer will overheat if too long or wrong gauge of cord is used. Also if run on generator with voltage /cycles incorrect. Under normal use, motor will not get very hot. Another problem with overheating is that the grease will melt out of range to do any proper lubrication. If you are sure that it is getting proper voltage /amps then may need lubrication or bearing work. Remove bearing cover and turn armature by hand. It should be easy to turn. If stiff, suspect bearing/grease. With amp meter connected, check amp draw and compare to rated amps.
Mar 26, 2011 | Bosch Brute Breaker Hammer 11304
My spedo and rev counter are not working!need to fix
if either pointer or ( needle ) is damaged a new clock will be needed, allso check condition of both drive cables that go to your clocks remove with plyers or fingers if poss, then trace back to engine and front wheel, allso disconnect ,turn inner cable with your fingers the other end will turn if good. the end of the cable should be square ,and not rounded off ,allso oil cable from the top if stiff.
Feb 14, 2010 | 1981 Yamaha XS 400
Need to reset password on my phone
1. Turn the Moto Q off
2. Hold down the power button (hang up button) and the center key button (the button between the arrows) at the same time.
3. When the verizon logo appears on the device. Let go of both buttons.
4. A screen will come up saying to do a Master Reset. You will hit the left soft key to say yes to confirm.
Your Moto Q is now been hard reset ( Master Reset )
Jun 27, 2009 | Motorola Mobility Moto Q
I have a GIANT LA FREE SPORT ELECTRIC BIKE. THE BRAKE CABLES HAVE BEEN PULLED OUT AND THE MOTOR WONT TURN ON. THE BATTERY IS CHARGED AND THE LIGHTS GO ON. WHERE CAN I GET BRAKE CABLES OR BRAKE SWITCHES? DO...
The brake handles have each have a switch button that must be pressed for the motor to work. (Actually what happens is that when you pull the break lever it unpresses the button so the motor won't work against the brakes). Just tape the switch down for the time being. Electric Bikes Northwest and David Hawkins might be able to help you with bike parts. I've gotten some parts from him for my La Free Sport. Very few bike shops know anything about these bikes. Good Luck! Dennis
Jun 19, 2009 | Electric Bicycle Motor, Bike,electric...
Cycling Logo
188 people viewed this question
Top Electric Cycling Experts
Eric Hidle
Level 1 Expert
Colin Stickland
Colin Stickland
Are you an Electric Cycling Expert? Answer questions, earn points and help others
