Question about Lands Phones
I am trying to connect a cat5 cable to a Systimax DATA connector
I am trying to connect a cat5 cable to a Systimax MPS100E-112 MPSB DATA (plug?). Does anyone know where I can find instructions on wiring. Illustrated would be nice.
  • 299 Answers
The systemax jack you reference should have a sticker showing the proper location to terminate each of the wires. Lay each wire in the matching slot once you have decided wheter to to use the 568A or 568B standard (makes no difference as long as both ends are wired the same. 568B is more common.) If you google "ethernet cabling" you will find dozens of sites with good illustrations to help you.
Posted on May 01, 2010
Can the connector in my ihip armour craft be replaced
If it are special connectors there should be special connector plug pliers for it and mounted like to made by the same way as for example cat5 cable connectors .
There should be a special tool to find IN YOUR COUNTRY . where they sell that brand.
It should exactly be the same for special mini plugs if there are 5 to 6 separate wires in the cable, but if its only a 3 wire cable then its easy to soldering a (mini) jackplug
How to Crimp RJ45 to Cat5e or Cat6 cable
Dec 01, 2016 | iHip Audio Players & Recorders
Whose company give CAT5 cables which give better result for high speed data sharing?
Tripp Lite:
Features
  • Cabling for category 5 (Cat5) and 5e (Cat5e) applications
  • Length: 3- Ft. color: black connectors: RJ45 male
  • Feature molded connectors with integral strain relief
  • Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation
  • PVC 4-pair stranded UTP
  • Rated for 350MHz/ 1Gbps communication
  • Meets most current industry standards including IEEE 802.3ab, IEEE 802.5 ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e draft 11)
  • Available in other colors and lengths
  • Also available without the snagless feature (N002 series)
  • Also available - Cat6 cables (N201 series)
Power Protection Power Distribution Cabling Tripp Lite
Feb 04, 2015 | Computers & Internet
I need networking cables, which cables are best for use.
CAT6 cables & jacks are better than CAT5E.
CAT5E cables & jacks are better than CAT5.
CAT5 cables & jacks are better than CAT3.
CAT3 cables have problems going faster than 10Mbit/second.
CAT5 cables support 100Mbit/second, and seem to work with 1000Mbit/second ("gigabit") devices.
Apr 01, 2014 | Computers & Internet
I'm having problems with my Linksys ezxs55w switcher. The plugs are not lined up with the correct lights. For example, I plug the uplink into the uplink plug, but it shows up as number 5. Same with other...
You have a 5-port router. The 5th port can be used either as an "uplink" port (with a cross-over Ethernet cable) or as a "data" port (with a straight-though Ethernet cable).
You've not provided enough details to trouble-shoot the "staying online" problem, i.e., IP-addresses of each of the connected computers/printers, whether you're using CAT3 or CAT5 or CAT5E cables, whether you've tried different Ethernet cables, and whether the router is connected into a UPS that provides "smooth" power.
Dec 27, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
I dropped my laptop and it landed on the cable where i plug in the Rj45 (CAT5) cable and now it's loose and doesn't connect. Please help.
Easiest fix is to go wireless, either that or the laptop will have to be opened up and the bracket support that holds the cat5 connector will be bent inside
Jul 14, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
What is Lucent 7 Cabling?
Lucent 7 cabling *probably* refers to level 7 Lucent cable. It's old!! There are two issues in the question of, "What is Lucent 7 cable?" Here's the history: Lucent was a division spun off by AT&T back in the mid 1990's. Then Lucent actually spun off Avaya and sent their structured cabling business with it (they had named the cabling brand "Systimax" by that time. CommScope bought Avaya back in 2004, so Lucent's Systimax brand of cabling is 2 generations out dated. It's still probably okay, but not worth today's money for new Systimax products made by CommScope.
Now for the 7 issue: there was no talk of category 7 (cat 7) back when Lucent was making cable, but Anixter, a data cable distributor, rates cabling with their own proprietary system called "Levels". Therefore, Level 7 cabling is an Anixter measure and many people have bought from Anixter long enough that they ask for level 7 [brand whatever] cable.
Use it if it's low cost. Otherwise, don't let someone sell Lucent branded-cable as the same as today's cable. There were version upgrades since then. The print on the cable jacket will say 1071C or 2071C or something like that. Today, they are on version E, not C.
Hope it's kind of clear. My guess is the cable is about 10 years old, although some data folks are stuck in their ways and still refer to today's Systimax cable as Lucent cable.
Apr 14, 2009 | Lucent Computers & Internet
Plz explain me exactly for which purpose RJ-45 cable used ?
RJ -45 is a type of connector used on cat5, cat5e....etc cables to connect networked devices...the RJ stands for registered jack but there is really not much you really need to know about it....a RJ 45 JACK is a little bigger than a telephone jack, you'll notice the female type of input on your computer or laptop and the male end will be on the end of the cable that goes into this jack....hope this helps
Apr 13, 2009 | Cat5e Cat 5E Modular Plugs - For Round...
Phone to Cat5e cabling - How do I wire the wall plate
Wire your phone box using your Cat5 cable, use 4 wires instead of 8 wires of Cat5.
Nov 20, 2008 | Cat5e Unshielded Twisted-Pair Patch Cable...
Cat5e to RJ11
You wont be able to....You need another NIC...you can Pick one up at Circuit city of best buy for about 10 to 15 bucks.
Nov 04, 2007 | Cat5e Cat 5E Modular Plugs - For Round...
Lands Phones Logo
47 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
