Question about Protron PLTV-32 Television
Loud sound from tv
We just had our Protron 32" LCD make this loud buzzing/crackling sound, the thing is the volume is all the way down? Is there some internal component that is faulty? Do I need to buy a new one rather than fix it? Please help!
It could be the inverter board going bad. The inverter board is what makes the back lights come on and has transformers on it that have high voltage. any time you have a noise like a buzzing or arcing you should have it checked
Posted on Mar 25, 2008
SOURCE:
My father has a Dynex LCD TV, Model DX-37L130A11 Rev A, sticker says 10H07-Rev A. Manufactured August 2010, Lot #: 205204 XHT 100453. A few days ago he said the audio started emitting a loud, cracking...
It sounds like you've done quite a bit of troubleshooting, which I applaud you for doing. Have you tried power cycling the TV? Simply turn off the TV, unplug it (and any components connected to it), then plug it back in and turn it on after a minute. See if this corrects the issue. If it doesn't, then I would recommend calling our Product Support team to schedule repairs at:
U.S., Canada, & Puerto Rico - 1-800-305-2204
Mexico - 1-888-882-7326
daily from 7 am - 12 am CT.
Sep 04, 2013 | Dynex Televison & Video
Luckinfutz, My Protron 32in LCD tv speakers crackle and even when the volume is all the way down we get this loud hum for about 5 seconds. I think the speakers are shot and are on their way out. I read...
Yes, changing the audio board might solve your problems. But the loud hum is the generated by either a bad connection (open the case and check all of them) or a bad filtering of the power (check the capacitors on the power board) so try fixing it first.
Mar 27, 2010 | Televison & Video
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Need replacement speakers or specs. to find matching replacements for Protron PLTV-32 TV. Attempted to connect two main front speakers from a surround sound set, but no sound until volume at 95% - then...
Shopjimmy.com seems to have them in stock.
Go to that web site and put in "PLTV-32 speaker" as the search.
They are going for $24.95 a pair.
I hope I answered your question. Please rate me. :)
Mar 16, 2009 | Protron PLTV-32 Television
Slight crackle on left speaker if turn volume up
the speaker is bad when you set the loud button on, you're putting more pressure on the speaker beacuse its bad it wll make that crackle sound. My advice change it.
Mar 03, 2009 | Panasonic CT-27G7 27" TV
Rca l26wd14 buzzing
Hi!
I have seen this before in a lcd tv I worked on! My problem was some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). But also check the signal board (rca s-video etc... inputs). My thought in this was a bad cap was producing a harmonic, causing the speakers to squeal! Good luck, I hope this is helpful!
Mar 02, 2009 | Samsung LN32A540 32 in. LCD HDTV
Continuous crackling from TV speakers
I'm sure you have figured this one out. TV itself is causing the problems.
The circuit board that produces the audio signal seems to be the problem.
Before you call the repairman, go to the web site Shopjimmy.com just to get an idea of what the parts will cost. That way he doesn't rip you off.
I hope I answered your question correctly. Please rate me. :)
Feb 26, 2009 | Samsung LN-T3253H 32 in. LCD Television
Sound has turned into a loud buzz
check,probably you change the sound module or if you can work efficiently on the module ,u change the sound ic & the entire electrolytic capacitor within the circuit.
Oct 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Buzzing sound coming from speakers
You maybe be able to turn the internal speakers off through the tv's menu...either in the Audio section or in Settings
Mar 15, 2008 | Proview PA-32JK1A 32 in. LCD Television
Protron PLTV-32 Television Logo
293 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
