Question about Toshiba e-Studio163 Copier
My e-studio 163 copier indicate code error c44
  • Toshiba Expert
  • 414 Answers
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards
Posted on Aug 30, 2012
  • 36 Answers
08 mode- 400 set to '' 0''
check thermostat continuity
Posted on May 25, 2010
2 Suggested Answers
  • 30 Answers
SOURCE: My e-studio 163 copier indicate code error c44 and
Hi how are you this is jack (Jack_pak@hotmail.com)
your copier show error c44..
Dear you press 0 and 8 key simantenasly and On copier other hand.. copier panal show ..AJ.... after 1min AJ constand.. then you press 400 and Start key.. your copier show one value 5.or.6 or.7..every x.y.z ok.. Then you press 0 key and press intrept key.
COPIER REVERSE AJ MODE THEN OFF COPIER..
AND simple ON Copier.
DEAR PLEASE VOTE ME.
Thanks ,
Best Regards,
Posted on Aug 14, 2010
Testimonial: "it was perfect and many thanks"
Toshiba e studio 18 error c43 how to reset
Dear sir i have to problem in Toshiba estudio 18 error c44
and fuser unit check ok but please tell as error reset
Jan 05, 2014 | Office Equipment & Supplies
Error c44 studio
codes c43, c44, c45
problem with the fuser
thermistor review
thermal fuse
check connectors
Dec 05, 2013 | Toshiba e-Studio 35 Copier
Error codes and their meaning for Toshiba e-studio 181 copier
toshiba e-studio 181 is not working. It shows that cover is open symbol and tells the same and the printer is woken up. what to do to rectify it.pls
Apr 27, 2012 | Toshiba e-Studio 232 Black and White...
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
My e-studio 163 copier indicate code error c44 and how can i clear the code
Thanks ,
Best Regards,
Jun 04, 2010 | Toshiba e-Studio163 Copier
Sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
Jul 20, 2009 | Toshiba e-Studio163 Copier
My Toshiba e studio 167 is showing a c44 error code. What should I do?
the c44 error is an error in the fuser if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.. Good Luck A
Jun 30, 2009 | Toshiba E-Studio167 Copier
Toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Mar 31, 2008 | Toshiba e-Studio163 Copier
Toshiba e-Studio163 Copier Logo
273 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
