Question about HP vs15 15"LCD Flat Panel Monitor
Sounds does not work even trying to check it over and oveR. It also flickers and light comes too fast or is to blurry.
    President:
  • 1,768 Answers
You may have an issue with the main board.
Flickering is a result of a malfunctioning inverter which also ties to the power supply which will not allow voltage to the sound module if built into the main board. You monitor will need service.
Posted on May 01, 2010
Have emachines monitor which is not coming on power button fast flicker
Which power button is flickering (your computer, or your monitor).
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | eMachines Computers & Internet
Left indicator light flicker too fast
If the right side works properly, switch all indicator bulbs one at a time. test with each bulb change. Untill you find the one that makes it flash at the rite timing. I had a bad rear bulb. The brake filiment was laying on the tail light filiment. This made the blinker timing bad.
Jan 26, 2014 | Hyundai Tucson Cars & Trucks
Hi I am trying to find out how to stop my
First check your lens and make sure it is clean. Second, try taking a photo outside in daylight using your timer, with your camera sitting on a solid stable surface. If the photos are still blurry, try setting your camera options to factory default and redo the same test. If the photos are still blurry, I would suspect the camera is defective.
Mar 22, 2010 | Vivitar ViviCam 8018 Digital Camera
Blurry Display Screen and 2 beeps with shutting Off
check the mode that the camera is in try to put it in auto mode, if its in other mode like fast motion etc it can cause this blurry pictures
Jul 13, 2009 | Samsung S860 Digital Camera
RCA W40D20 HDTV intermittent flicker and it gets blurry
loose connection on ends check you hdmi cable vga cable and vgi cable so the pins are good or not bent try to borrow another and see if it changes it and dont go to far from your tuner .
Apr 21, 2009 | RCA Scenium D40W20 40" Rear Projection...
98 accord wont start. lights flicker in dash and engine wont turn over
Have the battery checked.  You may have heard a fast clicking sound when the lights were flickering, if so it's coming from the starter solenoid.  If the battery is bad, have the voltage regulator and alternator checked also.  A bad voltage regulator or alternator will kill the new battery.
Try starting with jumper cables, if that works, you can pull the battery out, take it to a auto parts store that will test it for free (most parts stores will do this).  If it's bad, you can put a new battery in and then drive straight to somewhere to have the charging system tested.
Oct 31, 2008 | 1998 Honda Accord
Blurry indoor photos C-750
Use A mode and set the biggest aperture you can set (f3.5 ?) this this will then allow the camera the fastest shutter for the availbe light. In low light conditions this still may onlt be 1/4 sec which is still to slow for hand holding a camera. Best you turn your flash on huh.
Sep 12, 2005 | Olympus Camedia C-750 Ultra Zoom Digital...
Blurry pictures
What you are experiencing is a phenomenon called camera shake. Camera shake is caused when there isn't enough light for the camera to set a fast shutter speed. The camera's shutter opens and has to stay open for up to several seconds for enough light to hit the CCD to capture the image. Most people cannot hold a camera perfectly still for more then 1/60th of a second. In addition, when the telephoto feature is used on an Ultra Zoom camera, the field of view becomes smaller. Since a lens with a large focal length provides a small picture area, even slight imperceptible camera movement will cause a blurred picture. To reduce camera shake, try one or more of the following when applicable: Change to a fast shutter speed. Put the camera on a flat surface or use a tripod. Brace yourself against a tree or wall. Put the camera in sports mode. For situations with low light, raise the ISO. (Please note this will impede image quality)
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Blurry pictures
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
HP vs15 15"LCD Flat Panel Monitor Logo
53 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
