Question about Car Audio & Video
Sansui DVP-2002B car player - can only get black and white screen
we have Sansui DVP-2002B in our car. We changed the car battery and now can only get a black and white picture. The kids aren't happy! Any ideas how we can fix it. Many thanks
SOURCE: NECVOX ROOF MOUNT SCREEN WITH DVD PLAYER - tuning problem
try tuning in on the radio from fm 87.0 87. & so forf 1 digit up I think I am tuned in on 87.7
Posted on Mar 26, 2008
  • 10 Answers
SOURCE: SONY DVD PLAYER DVP-SR200P BUT IT ONLY SHOW IN BLACK AND WHITE ?
You have posted this in the Panasonic DMR-ES30VS section.
Please note which product section you are in before posting your question.
For the Sony DVP-SR200P there could be multiple reasons for it only showing in B&W.
Was this a recent problem, is this a new hook-up, has it always been this way?
  1. In the setup menu there is a setting for Custom Picture Mode.
    Could someone have turned the color down?
    You can go to the setup menu and "Reset" the player to the factory settings.
  2. How is this connected to your TV?
    Check all cables to make sure they are plugged in, test each one by unplugging it, and then plug it back in fully.
    If you are using a composite cable (1 cable yellow plug), be sure you have plugged it in from yellow to yellow.
    If you are using the component (3 cables red-green-blue plugs) hook-up, be sure you are using cables only designed for component hook-up, and have plugged them in correctly, red to red, green to green, blue to blue (Be sure you've plugged the red cable into the red video not red audio).
    Are the cables in good condition?
    No breaks, loose connectors, they weren't smashed under a piece of furniture?
    Have you tried a different set of cables?
  3. Test the DVD player on another TV.
    Does the same thing happen?
    Did you "Reset" the DVD player?
    Maybe the DVD player is bad?
  4. Find another DVD player and test it with your TV.
    Does it work OK, or is it black and white too?
    Maybe the connectors on the TV are bad?
    Is there a custom setting on the TV for that connection?
    On some TVs you can adjust the settings for each input (INPUT 1, INPUT 2, ....) maybe the color setting is turned down?
There are may possibilities, but these are some of the basic things to check.
Best wishes,
-Greg-
Posted on Sep 14, 2009
  • 3 Answers
SOURCE: Side BY Side Picture On TV Black And White
My mother-in-law sent me her unit with the same problem. The problem i had was you couldn't really read anything on the screen in the setup menu. I finally got lucky and got in the right menu and set everything to default settings and it went right back. Here are the steps to reset it without reading it.
1. remove all tapes and discs
2 if your unit scans for channels when you turn it on press return once
3.if it doesnt go to channel scanning you should have a blank screen
4.press the functions button once
5.press down twice
6.press the enter button
7.press the enter button again
8.press down once
9.press right once
10.press down 4 times
11.press enter once
12.press up once
13.press enter once and the double image should be gone
14. press the functions button twice to exit
hope this works for you
Posted on Feb 06, 2010
  • 12 Answers
SOURCE: black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
Posted on May 03, 2010
brownline45
  • 310 Answers
SOURCE: Sony portable DVD player wont load DVDs
maybe the spindle motor is defective so it cannot read the disc. just bring that your dvd to sony service center to fix your dvd.
Posted on Jun 19, 2010
I opened my Sony portable DVD player and my screen is white and black with lines on it, what do I do to fix it?
Your problem description does not give a clear idea about the issues. I'm considering the that the pictures are displaying in black and white for the new Portable DVD Player. Please follow the troubleshooting steps from the link given below:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C89600
If the issue is with the screen, please reinsert the battery and check if that helps.
Oct 21, 2010 | Sony DVP-FX810 Portable DVD Player
Dvp-fx810 screen blank and buttons do not respond. suspect bad connection from unit to swivel screen. can this be repaired?
Hi you probably turned the screen the wrong way take off the battery undo all the screws (heaps) take the base off and check the black and white plug hasnt pulled out of the sockets push them back in, unless you turned the screen around and around and ripped them out this may be the cause when putting the screws back in careful you dont thread them as it is easily done good luck
Mar 26, 2010 | Sony DVP-FX810 Portable DVD Player
No picture i only hear sounds, its blackout.
Jan 14, 2010 | Sony DVP-FX810 Portable DVD Player
Sony cd/dvd player dvp ns67p with black screen show
try switching the plug ins ( the colour wires9red,white,red)
Dec 16, 2008 | Sony DVP-NS300 DVD Player
Black and white picture
Have the RGB settings been messed with?
Jul 08, 2008 | Sony DVP-NS300 DVD Player
Sansui SAN1880 80g dvd recorder no colour
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
Thanks
Rod
Mar 01, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
Car Audio & Video Logo
22 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
