Question about Brother MFC 210C All-In-One InkJet Printer
Brother mfc215c cartridge/ink problem
Unfortunately that did not work - it is saying install black, when I have installed and also when I installed the rest. Help...
  • 832 Answers
Then check the led control board. is it still plain to the plastic of the holder or is it pushed out of position. If so open printer and simply click it back into positon.
Posted on Mar 25, 2008
SOURCE:
I ran out of the other color cartridges, and just bought a new black ink cartridge only. So can it work without the other color cartridges, and only on the black ink cartridge, because every time I try to...
No many of the printers will need to have both the color and the black cartridges to work...
You will have to purchase and install a new cartridge to get it working correctly.
heatman101
May 17, 2011 | Brother MFC-290C Printer
The printer says so ink cartridge installed on black.
my hp officejet pro 8500 wont make copies, it says replace yellow ink cartridge. can i not take the yellow cartridge out an still make copies?
Oct 01, 2009 | Brother Multi-Function Center MFC-240C...
New black ink cartridge - Machines says No Cartridge
just clean the place where your ink is installed clean it with cotton and alcohol..try to reinstall your ink slowly and make sure it contacts properly..hope this works...ITTech7574
Aug 28, 2009 | Brother MFC 240C All-In-One InkJet Printer
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
MFC does not recognise the new black ink cartridge.
Disconnect power supply and USB lead (leave disconnected for 10 min). Repeat this for each colour that is not working and hey presto the LCD readout will revert to normal and you will be able to print again. Happy Christmas! Hope this works for you (worked for me)
Dec 18, 2008 | Brother MFC 210C All-In-One InkJet Printer
DCP-130C COLOR INKJET
When inserting a new cartridge, you may receive a prompt
"The installed ink cartridge differs from the original ink cartridge for the printer. Your printouts may be different from those printed using original ink cartridges. Do you want to continue using the currently installed ink cartridge?"
If you click Yes, printing will continue. If you select No, you will be prompted to change the cartridge. Manufacturer prompts may vary.
Nov 21, 2008 | Brother MFC 420CN All-In-One InkJet...
Not recognizing cartridge
myprinter tells me"noblack ink," they are both b it is brand new cartridge why?this is the second black ink cartridge i have bought it says the same thing.i always buy "BROTHER"
Oct 27, 2008 | Brother MFC 420CN All-In-One InkJet...
How to Override Ink Level Gauge When Using Refilled Cartridges
Above link great.
If you have a newer print cartridge cart, look for the little window. I put a sticker over the little window on the Brother (innobella) LC38 cartridge cart and it worked great :)
Despite finding a fix for this problem, I think this is a rip off setting on the brother printers and I will never buy another Brother printer for this reason.
Jul 04, 2008 | Brother MFC 420CN All-In-One InkJet...
Say's empty
If you still need help:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.html?reg=us&c=us&lang=en&prod=dcp110c_us
Why does my machine's LCD show "NO CARTRIDGE" even though I have already installed all the ink cartridges?
Description:
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridges, then one or more of the cartridges may not be properly installed. Verify that the cartridges are installed correctly by following these steps:
Note
    Cartridges that have already been installed are no longer vacuum-sealed, so it is very important that these cartridges remain upright. If a cartridge is removed from the machine and placed on its side, air may be introduced into the ink supply tubes. As a result, repeated cleaning will likely be required before normal print quality is restored.
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    If the date and time appear on the display, the issue is resolved. If the display continues to show NO CARTRIDGE, continues to Step 2.
  2. Open the scanner cover by lifting it from the right-hand side until it locks securely into the open position.
  3. Remove the black ink cartridge by pulling the white plastic hook (locked over the edge of the ink cartridge) toward you, then lifting the cartridge out.
  4. The LCD should prompt you to install the black ink cartridge.
  5. Reinstall the black cartridge. Press down FIRMLY on the top of the cartridge until it is fully seated. Push the white plastic hook towards the cartridge to verify it is fully latched over the cartridge's top edge. Repeat STEPS 2 - 4 to verify each that of the color cartridges (magenta, cyan and yellow) is installed properly, then continue to STEP.
  6. Close the scanner cover. The unit should begin cleaning automatically.
Please remember to rate all Techs who assist you for free :) Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 01, 2008 | Brother DCP-110C All-In-One InkJet Printer
Intellifax 1860c no cartridge or replace ink keeps showing up
I have 1860 fax machine. It says that the black cartridge needs replacing. I buy a new cartridge and put it in and is says to install a black ink cartridge. I reinstall the cartridge several times and it says to install a black cartridge. Any help before I smash this piece of **** fax machine in the driveway?
Aug 08, 2007 | Brother IntelliFax-1860C All-In-One InkJet...
Brother MFC 210C All-In-One InkJet Printer Logo
116 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
