Question about GE 30 in. Profile JGP933 Gas Cooktop
I just spilled water onto my gas cooktop and now it won't light by itself. (doesn't even click and I have to use a match) GE profile gas cooktop about 7 years old.
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Posted on Aug 30, 2010
The cooktop just keeps clicking (trying to light) even when no eye is turned on.
My cooktop (GE)keeps clicking when it is plugged in.It did get some water splashed on it from a teapot.I have tried the hairdryer with no luck yet. Hopefully by tomorrow it may dry out. Any comment? robertgharris@comcast.net Thanks
Nov 09, 2010 | GE 36 in. Profile JGP963 Stainless Steel...
My GE gas cooktop keeps making a clicking noise and one of the four burners doesn't ignite unless I light it with a match. What should I do?
the burners use a sw on the gas shaft of each burner to make the igniton work. i belive one of the sw are shorted or housing broken . replace it . / tip when I replace one i do them all .. saves time later . falure caused by spills ect and normal ware .. mm
Jul 16, 2010 | GE Profile JGP636 Gas Cooktop
We have a GE free-standing range top. I spilled water everywhere when my pot overflowed, and the clicking noise will not stop. All burners burn though, what to do?
This is a very common problem when moisture comes in contact with the ignitor. The ignitor sometimes stays in one position causing the clicking sound. it will eventually wear itself out. Best thing to do is try to take it apart, clean it, dry it and adjust it if necessary. If that doesn't work for you, then the ignitor may have to be replaced. Good luck
Jul 11, 2010 | GE Profile JGP636 Gas Cooktop
A technician replaced the ignitor module and
one of the switches is still stuck on ignite try to isolate which one it is most likley there is still liquid causeing it to stick ie grease something stickey check the valve that sends gas back to the rear burners again it sounds like not all of the liquid has been removed look closley and always be safe
Apr 12, 2010 | GE JGP975SEKSS Stainless Steel Gas Cooktop
My ignition for the gas cooktop is clicking without being in the on positoin. will this be caused by cleaning with water? is it going to cause problems?
One of your burner ignition switches is fried. To see which one it is you remove a wire from each one till the ticking stops. Or plan be just unplug the stove and light it with a match.
Mar 12, 2010 | GE Profile JGP636 Gas Cooktop
Have a four burner gas GE Profile cooktop. How do
The igniter module is working fine. One of the switches (which are on each valve shaft) is stuck or shorted out. Pull a wire off each one at a time to determine which one is bad. Careful! 120 volts to each wire. Also, this can happen after you spill water into the valve area, if that sounds right, let it dry out.
Jan 29, 2010 | GE 30 in. JGP328 Gas Cooktop
Viking gas cooktop vgsu161-6b sparks continuously. There is no gas leaking. I spilled water on the controls and it is only when I turn on the 3rd knob from the top that this happens.
The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry though no permanent damage has been done. Leave it unplugged from the electrical outlet for a day or two until the liquid dries out. You can manually light the burners with matches or a BBQ lighter in the meantime. If you want to try and speed up the drying process you can use a hair dryer.
Oct 20, 2009 | Viking 37 in. VGSU161 Gas Cooktop
The burner will not click to light but will work when lit with a
replace the ignition coil if no sound clicking,but the parts is expensive? is ok to use macht.
Jun 30, 2009 | GE Profile JGP636 Gas Cooktop
GE Profile igniter sparking continuously after water spill
The continuous sparking stopped after few hours. Looks like the water dry up and that fixed the issue.
Mar 19, 2009 | Jenn-Air JGC8536 Gas Cooktop
GE Profile Gas cooktop stove- buzzer won't stop
Unfortunately you have to wait until it dries out. I have tried hairdryer before but most of the time I have had to leave it off overnight. FYI if you dont shut off at the circuit breaker and the sparking continues it will short out and definitely get worse
Feb 09, 2009 | GE 36 in. Profile JP968 Electric Cooktop
GE 30 in. Profile JGP933 Gas Cooktop Logo
927 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
