Question about Audiovox FPE3206 32 in. LCD Television
Audiovox FPE3206 HDTV - blown power supply-burnt resistor. Part number LT32T18-20. Need to know where a replacement power supply can be found? Any suggestions? Ken, Wahiawa Hawaii
    President:
  • 1,768 Answers
The manufacturer is the source for parts or call them and ask them if they have a part distributor near you or online for ordering.
You may also ask the local TV shop to order the part for you for a small shipping fee.
Posted on May 01, 2010
FPE3206 - I have blue power led lit and no pic or audio. Thought it was the inverter but wasn't. Power supply has 5v. Did not get the 24v reading. I have 2 bad surface mount resistors on the main....
The tv main Tuner signal board it is dead and it is the causes,if u have 2 burn surface mount resistors on it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole main Tuner signal board for the replacement.
May 31, 2011 | Audiovox FPE3206 32 in. LCD Television
My 37inch lg lcd television was working this morning i came home now and it will not switch on, just the power light flashes green then red? can any one help me
The power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 26, 2010 | Audiovox FPE3206 32 in. LCD Television
MY TV TURNS ON BUT NO PICTURE OR SOUND I HAVE A AUDIOVOX FPE3206 MODEL
you could have bad capacitors in power supply.You can probably see the they normaly have flat top.If top is round like a bubble it is bad.This is common problem with flat panel lcd tv and monitors
Feb 22, 2010 | Audiovox FPE3206 32 in. LCD Television
Fuse and power supply look ok to the eye slight static sound on audio tiny flash intermitent inright corner on video, any clues? power diods check good ,nothing looks hot or burnt There is a second board...
Your power supply on the dc output should have the floowing DC voltages, 5v, 12v, and 24v. Just start probing the connectors of the power supply. 24v is needed for the backlights inverter board, 12v for sounds, 5v for logic board.
Dec 09, 2009 | Audiovox FPE3206 32 in. LCD Television
Tv power comes on but no picture th name Audiovox
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 01, 2009 | Audiovox FPE3206 32 in. LCD Television
Tv screen went black and no sound
Look at the power supply first; look for burnt parts, bad capacitors, etc.
Please post back what you find. It sounds like at least you do have the 5V standby power supply working but the main supply is not getting the 'ON' command from the main board, or the power supply is gettin ght e 'ON' signal but failed to turn on.
Sep 25, 2009 | Audiovox FPE3206 32 in. LCD Television
Audiovox FPE3206 - Power Light is Blue/ON but Screen is BLACK
I had the same problem, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Oct 08, 2008 | Audiovox FPE3206 32 in. LCD Television
Audiovox LCD FPE3206 problems
Same thing here. Seems like there is an issue with the power supply. There is an interesting buzzing sound coming from the power supply. The power supply is located underneath the rear panel of the set. The panel is relatively easy to remove and it looks like the Power Supply would be pretty simple to replace.
Would like to know where to get a new one. This TV is just over a year old and out of the manufacturers warranty period.
If anyone else has tinkered around with this set and has any other incite to share Id be very interested in hearing it.
Thanks
MacPointMan
Jul 04, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Resistor on power supply board
Dear Biigjohn, First, first C613 means that it is a capacitor, not a resistor.And It seems to be a electrolytic Capacitor.If it has burst, then it's can will be inside. just search. the details of the Capacitor will be on it. most likely it will be a 10mfd 160V capacitor. Check and replace.
Aug 14, 2006 | Sony KV-27V26 27" TV
Audiovox FPE3206 32 in. LCD Television Logo
178 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
