Water doesn't go to the drum it leaks all over the floor instead! seems to be coming out the draw
  • 807 Answers
Sounds like you have a hole in a pipe, or loose pipe.
Or the drawer could be blocked with washing powder and need cleaning out. The top cover comes off the machine on a lot of models and gives you access to the water inlet in to the drawer. If you can do it yourself check it. The drawer it'self may come out for cleaning, sometimes by pushing a little lever inside the drawer, or it may pull out at a bit of an angle.
If you have no one to take a look at it then you will have to get an engineer.
Posted on Mar 25, 2008
Water leak passenger side floor board
Drain is likely plugged up. Clear it out with either air pressure or a coat hanger.
Sep 04, 2013 | Ford Cars & Trucks
Doesn't always come on with hot water is turned on
Water heaters draw water into the bottom, and as the hot water heats, it rises and hot water exits from the top.
You might want to check each fixture, does the hot pipe (tubing)feel warm when you run it for a moment. Can you get warm water from some of the fixtures, but not others?
I'm bet there is a leak at the top of the intake which is filling from the top down, instead of bottom up.
Dec 27, 2012 | Water Heaters
Kenmore 54351 Dehumidifier is leaking -- water isn't going into the tray, but seems to be leaking out into the floor.
Mine is doing the same thing. The bucket is dry and the floor is flooded, so it is not an inability to condense, and it is not that the bucket has overflowed, and the bucket does not have a leak. It had been working great and then this suddenly started happening, it's as if the water is not flowing along the proper route and instead is gathering behind the bucket.
Nov 27, 2012 | Kenmore 54351 Dehumidifier
Hoover optima washing machine is leaking very badly . I have stripped the machine down and cannot find the leak . Inlet pipes clear. Cleaned soap drawer and two feeder rubber pipes don't seem to be a...
Hi,maybe the draw dispencer is damaged,I wouldnt think it is the drum seal,what I would do is tilt the washing machine so that the top of the machine is leaning against the wall so that the front of the machine is of the ground,then while you get underneath the front on the floor with a torch get someone to put water in the dispencer and see if you can see where the water is leaking from,I hope this was some help,all the best.
Mar 21, 2017 | Washing Machines
Water is coming out of the drawer when in a cycle and leaking on the floor
g'day, water fills up drum via soap draw. this is how the soap mixes with water and enters the drum. U might need to check hose clumps and hoses that enter onto the back of draw (you'll need to access the top of machine when machine is unplugged). Also be sure to clean draw as soap can build up causing problems. Be sure draw is closing properly. Hope this helps. Let us know how u get on.
Aug 08, 2011 | Washing Machines
Hi, I have a Haier HD306 Dehumidifier. I'm having an issue of the water dripping onto the floor. There is no crack or leak coming from the bucket itself. The leak seems to be coming from the back...
When my unit did that, I found that it was because the drain tube was plugged with lint and/or dirt...
Run a large tooth pick or wire up inside the drain and see if the water doesn't start running right out of there...
heatman101
Jul 26, 2011 | Haier HD306 Dehumidifier
Water leaking on floor from my front loader
it sounds like it's a prob from the water solenoid to the drum and/or the soap box there is a hose that runs between these items to get the water into the drum
Jun 11, 2009 | GE WSXH208A Front Load Washer
Water still leaking
If the water is running down the front from underneath the drawer, then I would say that the hose is blocked from the dispenser into the drum.
You need to remove top cover, locate large black hose from dispenser into drum, feel and manipulate it to free any blockage of soap powder..
If the water still does not go into the drum, then you are going to have to remove hose to clear blockage.
Plz rate my solution.
Thanks.
Jan 08, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
