Question about Razor E100 Electric Scooter by
When i try to drive my E100 scooter it doesnt go but when i press on the light turns on and i checked the wires its all there any help please???
  • gigikat Oct 25, 2012
    its maybe out of charge?
Its out of charge or its been used to much.
my advice put oil on the weel's and see if it will work
Posted on Oct 25, 2012
    Problem Solver:
  • 9 Answers
Have you tried to push the scooter like a normal non-electric scooter then while moving twisting the throttle? If not, then i dont know what to tell you except to get a new one.
Posted on May 06, 2010
ON/OFF SWITCH BROKEN ON SCOOTER E100
Replace the Red Illuminated Light On/Off SPST Rocker Switch 15A/250V 30A/125 - Switch number SWT-102050 should be available
at most scooter repair stores or online scooter repair for about $6.00.
Black wire goes to the Brass terminal lug. when removing the wires mark the location as Top, Center and Bottom and place the Black wire on top with the brass terminal.
to Search Online Type 'scooter repair SWT-102050' you will see a multitude of choices
Jun 30, 2014 | Razor E100 Electric Scooter
The scooter wont start
Take it back and get an exchange one. Or, manualy check fuse, check wires conected to throtle and motor. If it all looks ok then its most certainly a wiring fault
Nov 25, 2011 | Razor E100 Electric Scooter
I have an e100 that appears to be fully charged. The red light on the on/off switch is on but the scooter goes nowhere? I checked the batteries for output and goes 12.85 volts. The motor doesn't even...
If thats the voltage from the 2 batteries joined together then the voltage is far too low to run an E100, sounds like one of the cells has died, must have a 24v combined output.
Jun 28, 2011 | Razor E100 Electric Scooter
Hi i have a razor e100 today at a yard sale and brought it home and plugged it in and the green light turned on and i plgged it in to the scooter and the light tuned green so i pulled the plug out of the...
There are a few components to check when diagnosing electric scooter issues.
1. Batteries
2. Wiring
3. Controller
4. Throttle Assembly
5. Fuses
Once you inspect all of these for damage, you can test your motor and batteries, by bypassing the controller, and directly hooking the batteries to the motor. If the motor spins very fast, then you have good batteries, and a good motor. The controller will need to be replaced. If your motor spins slowly, you could require new batteries or Controller, or battery, depending on the results.
You can find replacement parts and service locator here.
urbanscooters.com/partsforscooters
Oct 02, 2010 | Razor E100 Electric Scooters Red
Have an e100 razor electric scooter. it has not been used for a couple of years. I got a new e100 charger and tried to charge but i noticed that the green light stays on and the red light charging does not...
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are available at:
razor.com
Jul 20, 2010 | Razor E100 Electric Scooter
My electric scooter turns on but the throttle doesnt work! any info ? :)
Replace the throttle. The throttle in these scooter are very cheap and wear out quick. You can find a throttle replacement at:
electricscooterparts.com
Apr 11, 2010 | Razor E100 Electric Scooter
Razor E100 reset button and no charge
Hi... My son hasnt used his Razor E100 for nearly a year as couldnt find the charger.. I finally found it and as soon as I plugged it in the plug was showing green light as that it was fully charged... When we turn the unit on it lights up but its dead... Where can I get the cheapest battery (and does it have 1 or 2)? Or you mention a reset button? Many Thanks...
Jan 24, 2010 | Razor E100 Electric Scooter
Razor E100 Electric Scooter by Logo
318 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
