Question about Fisher and Paykel Dishwashers
Fisher Paykel Double Drawer DD601v2. Half way thru a cycle the alarm went on both drawers even though the top one was not inuse or switched on. The error on both drawers is F1. If we push the power button on both after a few seconds they both start up making a whirring noise and both drawers flashing. We have to unplug the machine to stop the irritation. What is wrong and how can we mere mortals fix it ?
  • dave_blackwe May 01, 2010
    OK Silverdragon
    The manual managed to diagnose the prroblem thus:
    "Machine may be
    syphoning and has
    topped up too
    many times
    Check non-return
    valve and drain
    hose height"
    I need to know how to effect a DIY solution I have no idea how to check the non return valve or even where it is ! What does drain the hose height mean and what does "topped too many timres" mean?
    President:
  • 949 Answers
The F1 error means that the sensor that is located in the pan at the bottom of the machine has sensed water.
It does not want either machine to run with a leak so it will shut down the operation of both drawers.
First thing to check is if there is water under there or not. If you open the bottom drawer all the way you should be able to peek behind the back of it and see the 'floor' of the dishwasher. The sensor is near the back under a plastic cover.
If you do not see water the sensor board has failed. It is not too hard to replace but takes a bit of time and patience.
If you do see water then the hunt begins, you will have to find the source, it could be the lid seal or one of the hoses, but since the top drawer was running that would be the place to start. Let me know how far you feel comfortable in taking this and I will walk you through what I know.
Posted on May 02, 2010
  • Fisher and P... Master
  • 12,061 Answers
Http://www.scribd.com/doc/6462163/DD601V2-Manual
Servicing manual above.
Inside you will find all the answers to your problems and what to do... Download the PDF, to your PC, that's the best way.
Posted on May 01, 2010
My drawer on my fisher & paykel drawer sticks
I found a ball bearing stuck in one of the draw runners ?
http://www.scribd.com/doc/6462163/DD601V2-Manual see if this link still works
Sep 29, 2014 | Fisher and Paykel 24 in. DS-603 Built-in...
How to restore power to top drawer
Sorry some more information as to what the cercumstances are may help ?
Try this link anyway , Cheers
Sep 28, 2014 | Fisher Paykel 24 In. Panel Ready Double...
Top half of my dish washer beeps when i push the power button
you will find this diagnostic service document useful.
http://applianceassistant.com/ServiceManuals/dishwasher-fisher-paykel-dish-drawer-dd603-ds603-service.pdf#zoom=100#scrollbar=1
The likely reason for top drawer not starting wash program when you press start button is the drawer home sensor is either faulty or the drawer is misaligned. This means controller thinks the drawer is open and does not start the cycle.
Apr 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
F2 code on Fisher Paykel dishwasher
The problem is linked to rotor operation during discharge cycle. By replacing the rotor with bottom will only address part of the problem. There is very likely some obstruction in the pump cavity. This is the small channel connecting the drain sump and the pump cavity. Grab a thin but rigid wire and clear this channel. Usually a bone chip or some seed.
Also confirm if the top rotor worked ok when you moved it to the bottom drawer.
Mar 09, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel DD601v2 dishwasher
here's the manual..
i did not read thru the whole thing but there are quite a few removal items that i'm sure will lead you to drawer removal.
Hope this helps you.
https://www.scribd.com/doc/6462163/DD601V2-Manual
Jan 22, 2018 | Fisher and Paykel Dishwashers
Fisher Paykel double drawer built in top drawer stops mid cycle.
It would help to know which LEDS are on when it stops. Are you able to open the lid etc. Does this happen with the short rinse cycle as well?
Oct 17, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
The dishwasher top drawer is leaking all over the floor during the cycle. When the top drawer is running, It fills up the the bottom of bottom drawer with water also and then neither drawer drains...
Fisher and Paykel design a air gap kit to prevent the water back flowing to the other while one is running. it really works and worth of your money. You need to change the lid seal and a pair of actuators from the top drawer. Because of the leak then the floor switch activated not allowing a complete cycle. Need to dry out the wetness from the bottom housing of both top and lower drawers by pulling the tubes out and accessing from the left side with small tower until it completely dry. Here is a link to buy air gap kit http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Dec 15, 2009 | Fisher and Paykel DD605SS Stainless Steel...
Fisher paykel DD603 top drawer starts cycle then stops and beeps and doesn't go thru cycle
When it stops and beeps can you tell me all lights that are on when you open the drawer cheers. also check to see if the water in the tub is hot if not you have a heating issue. either a faulty element or Mtr Controller module. try swapping the Mtr Controller module (computer board) from the top drawer to the bottom drawer and see if that moves the fault. cheers
Mar 07, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Need Fisher Paykel DD603 SS-USA repair manual
Downloaded operator manual from fisherpaykel.com. This is not the repair manual I sought.
I was able to fix problem of top lid not clearing drawer by removing drawer, lubricating rubber gaskets, slides, and hoses with Armor All, then reassembling and cycling the timer at 12 minutes.
The lid then opened fully and did not hang up.
Mar 02, 2009 | Fisher Dishwashers
Dishwashers Logo
35 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
