Question about Sony Playstation 3 (PS3) Console
I need help getting online with my PS3. When I
I need help getting online with my PS3. When I tried to do it 'easy' it did not work. Then I did it custom and the IP worked but it said the DNS was the fault. I entered the same DNS on my computer and I don't know what the problem is... Can you help me please?
  • 27 Answers
Your DNS is generally your router or access point. That resolves DNS requests as either internal (on your network) or external. If external it forwards the request to the ISP's server. Check the gateway IP on your PC. If it doesn't work then try entering the DNS server for your ISP directly.
Posted on May 02, 2010
Hello my ps3 wilnot read a disc.. i changed the blueray player and it still will not read ne disc's
Dear,
Your PS3 is suffering from technical difficulties and you would have to get it repair. Now, you can either get it repair from Sony Repair Shop; OR you can fix it yourself at home from PS3 Online Easy & Complete Repair eBook.
This PS3 Repair eBook is highly CHEAPER and very easy to understand. Even a non technical person can repair his or her gaming console at home without anyone's help within 1.5 - 2 hours! All you need to do is download this PS3 repair guide and fix your PS3 with the uncounted diagrams and instructions provided for your convenience. I hope it would be helpful for you very much!
May 31, 2011 | Sony Playstation 3 (PS3) Console
Can 807101 ps3 be solved
If you keep getting this ps3 error 807101ff, then somethings definitely wrong with your online communication. To be specific, you are having what it called a DNS error. You see, the DNS settings on your network is your means of contacting and communicating with an online server. In the case of the ps3, that online server happens to be a game server. Without a correct DNS setting, your online network is "doomed", or put in another way, useless.
807101ff problem? It's really quite easy! What you can do is to try the POWER CYCLING method. To do this, turn off your ps3 and all of your networking devices like the modem and router. Remove the power cord of the router and modem as well, to be sure. You then wait for a short while, like a few minutes.
After the short wait, you can now connect back the modem and turn it on. After you get a solid light on the modem, connect back the router. The last thing you turn on is the ps3. This way, your ps3 would be able to try obtaining an IP address. Likewise, it will also try to establish a stable DNS setting. This technique works most of the time in solving the problem
Hope this helps you!
Any further questions feel free to ask.
Nov 20, 2010 | Video Game Consoles & Games
I am trying to get my ps3 online and i cannot seem to do it. every time i try to connect to the internet it says "DNS error (80710102)".. i have tried every idea i can find through online forums, nothing...
Sony PlayStation 3 generate lot of network errors ........ so don't worry, you can solve this easily ..... i got some problem with my ps3 and its resolved by the help of Repair Guide
it covers network problems thoroughly so check this out !!
it will definitely helps you
CLICK HERE
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
My son has a sony ps3 and has been trying to connect to play online games in ModernWarfare2, H cannot connect and actualy get into an online game. He receives a dlna error code of 7531. Can you help?
The PS3 YLoD can be caused by a number of things. Most commonly, it's a result of a hardware failure, overheating, dust build-up inside the system, and occasionally just due to loose cables.
Let's start with the easy stuff first to narrow down the cause. Follow the steps below:
1. Assuming you were playing your PS3 when the YLoD happened, move your PS3 into an open area with a lot of ventilation and let it cool down for 20-30 minutes. Once it's cool, try to turn it back on and see if that helped. If not, go to Step 2.
2. Unplug all of your cables from the PS3 including the A/V and the power cord. Also unplug the power cable from the wall. Now try to plug them all back in and make sure they are all secure. Turn the PS3 back on and check if it's working. If not, go to step 3.
How to Fix PS3 Yellow Light on Your Own
3. Get a vacuum with a hose attachment and vacuum out the vents on the system. Sometimes dust build-up alone can cause your PS3 to stop working properly. You might also want to take one of those cans of air and blow it in there to get some of the stubborn pieces of dust out.
If none of those solutions worked, the problem lies within the PS3 and you will probably need to take it apart to fix it. The most likely scenario is that your heat-shield overheated, the chipsets got shifted due to heat, and your solder could be cracked.
the causes of the yellow light of death
Here are some of the top causes of the PS3 Yellow Light of Death:
* Overheating - The unit gets too hot. Sometimes caused by too much dust buildup in the vents.
* Blu-Ray drive failure.
* Bad power supply.
* Hard-drive critical errors.
* Hardware malfunction on the motherboard - The solder starts to crack due to excessive heating and cooling.
if you have warranty then take it back if you dont then you can either try the repair yourself how ever this is not very easy to do and can cause more harm than good you will need special tools to take it apart and its not easy you also need an understanding of heat seal paste and heat sinks due to this being the part you need to remove and put back
i do the repair for about 25pound plus parts so if you are paying someone to do it then your looking at least that price, i only charge if the problem is fixed so try and get the best price you can.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks,..,
Sep 22, 2010 | Sony Playstation 3 (PS3) Console
Had my ps3 for year and half now, never played online (80710102)
Ok first off create a psn account online via computer, this is free of charge. Then after that connect your ps3 via cable to your modem. turn it on and access network settings. Then select internet connection settings, select easy. After it is finished select test connection. Should this time out it means you have a faulty connector somewhere, try checking your cables and the ports on the ps3 and modem. But if it states connected, back out and go to network via your ps3 dashboard then select sign in and enter your account info from your psn account.
Dec 08, 2009 | Sony Video Game Consoles & Games
Just wanted to know is there any way to get my ps3 online
try opening a portal from you router to your ps3, the router will shut down all the things it need to in order to play your games more efficiently. If that doesn't work try hard wireing your ps3 to your router. If your getting online on your ps3 wirelessly then try moving your router or your ps3 closer together.
Nov 08, 2009 | Westell Wirespeed VersaLink...
Online play for ps3
reset your router and modem, then go through your ps3 settings and do it on easy. this should work. if not try connecting it directly to your modem and see if that works.
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
Need help with ps3 internet hook up
you can go wireless, but personally wired is better. what router do you have? switch everything off, plug a ethernet cable from one of your ports on router to ps3 then then switch it all on. on ps3 go to settings - network settings - internet connection settings - then select easy - then whether you wanna do it wireless or wired (up to you) then let it do its thing, once its found all your settings you can test the connection.
Have you set up an account on your ps3 yet?
Everytime i try to go online with my ps3 it says ip address timed out
Your IP address is given by a DHCP server. This could be your router or your ISP. If you have a router the easy way to reset it is to turn the power off for 30 seconds and then power it back on. If you don't have a router, disconnect the phone line for 2 minutes.
You may need to reboot your PS3.
There are more things to try. e.g. giving your machine a fixed IP address (via control panel and networks) This works best if you have a router. If you need more help get back to me
Carrieone
Dec 11, 2008 | Computers & Internet
Ps3 online difficulties.
I look all
over the net but could't find anything, until i found a site that said they
could show me how to fix any problem with my ps3. At first i was not so
sure about ordering the manual but i did, whats $5 plus i used paypal, but
long story short i fix my ps3, i recomend this site www.gameme.20fr.com
i hope this help you like it help me. PLAYSTATION FAN FOR LIFE! waiting on PS4
Mar 03, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
