Question about Canon PIXMA MP780 All-In-One InkJet Printer
VERY FAINT PRINTING THE INK CANISTERS ARE ALL FULL
  • 4,041 Answers
Hi There
Maybe this good clean out will do the trick.
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on May 01, 2010
New black very faint
1. hope you have not touched the contacts or head those protected by pink tape.
2. or the ink is dried up
Replacing Cartridge HP Photosmart C4280 All in One Printer
Apr 06, 2016 | HP Photosmart C4280 Aio Printer
Printer not printing very faint
Clean or deep clean the black printhead. Go to 'printer properties' then 'maintenance' and click the appropriate button.
Feb 22, 2015 | Canon Pixma MP450 All-In-One InkJet...
How do i change scanner light bulb on hp psc 1205 printer
Most of the time the light bar is not the problem when it comes to print quality issues. Those are typically ink cartridge or printhead issues. Try printing a self test page and compare.
Dec 19, 2014 | HP PSC 1205 InkJet Printer
I am printing 3 pages the print on the pages are faint in two of the 3 pages. It is not low on ink because it prints the last page just fine. It's faint like its out of ink but it is not out of ink . ...
Squeeze a running garden-hose, and the water will spout out, but at a diminished rate.
If your printer has "nearly" clogged ink-paths, then the first page or two will be diminished, until the ink "washes" the walls of the ink-path, to finally allow more ink to flow through than on the first page(s).
Use the HP "Printing Assistant" software to run a "print-head-cleaning" cycle, to try to "unclog" your printer.
Dec 01, 2010 | HP Deskjet F340 All-In-One Printer
Myprinter will not print all colours they are mainly blue and yellow but very faint. I have carried out ALL the maintenace procedures several times without success and have checked that all the cartridges...
Click Start
Click Control Panel
Click Classic View
Click Printers
Right-mouse-click on your printer, and choose "printing preferences" or "properties".
There may be an option to control how "light" or "dark" the printing will be, i.e., use "less" or "more" ink per page.
Also, click "print test page", to ensure that the test-page has all 3 "primary" colours.
Also, click "clean ink cartridges", to try to repair any blockages inside the ink-cartridge.
Nov 17, 2009 | Canon Office Equipment & Supplies
Changed the print head in my Canon MP760 but now printing is blurred and very faint
Try cleaning the felt pads where the print head would rest when not printing. They get full of ink and cause more printing problems. I use water to clean them.Don't loose them, they are needed to keep the print head from drying out.
May 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
Ink cartridge full, but printing as if out/low
I have found using 3 r d party inks in Canon printers will mess them up fast but the ones with the contacts don't work period
Dec 01, 2008 | Canon PIXMA MP510 All-In-One InkJet...
Printing light blue will full ink
its either the catridge head is bad or yr new ink isnt too good although its new it still can go bad. now try using menthylated spirit sucked in a tooth brush thats not too hard . use it to clean the inside of the cartridge head. that is those spots inside. cos atimes dirty could cause such problems. so try it out.
hope this helps
thanks
May 31, 2008 | HP PSC 1350 All-In-One Thermal Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
140 people viewed this question
old marine
old marine
