Question about Lexmark X6170 All-In-One InkJet Printer
The paper won't pass through my printer what can I do
By pass tray on bizhub 250 only detects letter when i place an A4 paper, how do i make it detect A4
Clean the paper size sensor and change the by pass paper tray size setting on the display "Paper tray change" setting mode.
Mar 16, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
Says paper jam but paper still won't feed even after cleared.
May be have a tini part of papel and you don't see it or found it
i pass the same thing long ago.
or may just need a new one.
Good lock
Aug 20, 2011 | Office Equipment & Supplies
Anyone having trouble with canon printer pixma mp 210 not feeding paper. i have tried every thing that the maintenance tools have. reinstalled the software. there is in the center obstructing the path....
did the paper feed sideways if so there is something stuck in the feeder, here what you do fold the bond paper into half then feed it manualy open the cover of the printer so you can see the paper pass through push through until it will pass underneath the small roller then pull it out slowly be sure the paper pass all the small roller, dont forget to unplug the unit from the outlet before executing this step
Aug 03, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
My Kodak esp 3200 won't print labels on Avery label pages. WILL print the labels on regular copy paper. Any suggestions on what to do?
I am having the same problem except you didn't address the problem. It's not that the printer prints badly, jams or crashes. The printer literally passes the label paper through the printer and then prints on the next piece of copy paper. I reset my printer not to print the last page first and it still did it. Then I put the label paper second in the feeder. It passed through the first piece of copy paper and the
labels and printed on the third. It's like the printer senses the thicker paper and skips it. My printer is a Kodak ESP C315 and I have no setting for thick paper only plain and photopapers.
Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have this printer and says Rec. Paper jam but there is no paper in the printer.
which model do you have
may be some part of paper lying in it
try to pass thru full a4 size paper in it if it pass thru it will came with torn paper stuck in the paper path
Aug 13, 2010 | Office Equipment & Supplies
My Epson 1290 (some years old) doesn't grab paper, especially good inkjet paper) properly. It passes straight through, prints on the roller, and/or I get messages saying the paper isn't loaded properly or...
That could be from the rubber rollers not being able to grip the paper. They get polished or shiney over time with use and age. Then they slip or pull incorrectly and you get your problems. There are other things that can cause this but nothing worth fixing.
Fixing the rubber rollers is easy. You need some ispropyl rubbing alcohol and a paper towel. Make sure it is isopropyl type as this won;t attack other parts. Simpley wet the paper towel and wipe down the rubber rollers. You will see the rubber go from a dull shine to dull flat rubber. This takes off the buildup on the rubber and lets it grip again. Eventually the rubber will age harden and this trick won;t work but this can give you years more service.
Apr 20, 2010 | Epson Stylus Photo 1290 InkJet Printer
PAPER JAM CONTINUISLY AND GOING TO THE RIGHT SIDE FIRST BUT DO NOT PASS THE PAPER.
Good day SIr,
I have this problem with my printer (PAPER JAM CONTINUISLY AND GOING TO THE RIGHT SIDE FIRST BUT DO NOT PASS THE PAPER) and appear error this error on the screen:
Catridge Error 50C
Appreciating your assistance
Regards
Nov 28, 2009 | Lexmark X5150 All-In-One InkJet Printer
Hp laserjet 8150 printer jams from tray 3
Check the rollers in tray 3 to see if they are slick. If not, replace the paper input unit C4214-69017.
Feb 19, 2009 | HP LaserJet 8150dn Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
HP LaserJet 1100
Does it only whine when it paper is passing through it? Does it whine before the paper is fed in and after it's ejected? If so, could possible be the fuser unit. If it only whines when paper is passing through, it may be the paper passing between a worn-out feed roller and separator pad, which are high-mortality items on this model. Can you supply any more details?
May 10, 2007 | HP LaserJet 1100 Printer
Lexmark X6170 All-In-One InkJet Printer Logo
15 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
