Question about HP Pavilion dv1000 Notebook
Won't start up the windows, only shows HP Logo , and there is clicking on the hard drive.
    President:
  • 1,768 Answers
1. You may have lost the hard drive and or the hard drive may not be seated in the socket completely.
2. A replacement is needed.
Posted on May 01, 2010
My installed formatted hard drive won't boot!
maybe the HDD was the problem... but try your HDD to other laptop instead.. but if still it wont show/detect.. so i guess the HDD was the problem... so if the problem is the HDD.. all you need to do is to replace it....or you can contact your dealer..
Aug 06, 2012 | HP Compaq NC6220 Business Notebook
Ze4610 won't boot past HP logo
The hard drive has issues, the next step is to have it tested for possible replacement.
Jun 05, 2012 | HP Pavilion ze4610 Notebook
My HP pavilion won't boot. I turn on my laptop and all it does is sit on the hp start up logo i press the function keys but all it does is reject it. This happened after installing windows 7 and the...
It seems there is no booting as the memory is not responding or the hard disc is not booting up. Please check on the back up CMOS button cell battery on the back side of the laptop. replace if the voltage is low.
Also remove and reset the memory, if not you need to take consensus to know if this can be the hard disc, memory or the motherboard.
Sep 29, 2011 | HP Pavilion dv2000t Notebook
My HP DV9740US laptop will only recognize one external hard drive at a time. When i plug in another external hard drive it'll make the sound that it's recognized but won't show up in My...
you may have to assign a letter to the unseen drive manually: goto start menu and right click on my computer/ select manage/ select storage/ select disk management/ right click on the drive in question and select change drive letter and paths/ then give it an unassigned letter and that should do it. hope this helps:)
Jul 28, 2011 | HP Pavilion DV9740US Laptop
My HP mini 1000 shows blue screen after the MS Windows XP logo. it shows blue for 1/2 second so I can not read the message. It go back to start in safe more, start normally or restore since last good...
seems to be Your RAM is up to something.try with another known good RAM.
unless,Check the SATA mode at BIOS settings if it is AHCI ,change it to IDE
Jun 12, 2011 | HP Mini 1000 Netbook
OS won't load. Scan reported bad hard drive, replaced HDD, loaded recovery CD and rebooted, won't complete install. Placed HDD in external case and copied software to it, reinstalled in laptop but it...
You need to reformat the hard drive so that it shows a partition for the HP software. Call HP tech support and explain your problem. They should be able to tell you how to format your hard drive.
Mar 12, 2011 | Computers & Internet
I have a hp mini netbook and when i turned it on it started to tick. it was the speakers it was ticking from then bottom. and it gives the hp start screen (blue logo that says HP) then it goes black and it...
Sounds like the hard drive went bad, hard drives will click away when the platters are touching each other.
Take the hard drive out and see if the clicking is still there, if it is the motherboard at that point cause the sound is built onto the motherboard.
If the clicks go away after taking out the hard drive then you know the hard drive is definitely bad.
Dec 01, 2009 | HP Computers & Internet
My hpdv6000 recovery got stuck at 98% and showed 5 mins remaining then after 15-30 mins it moved to 99% and still showing 5mins! its been 30 mins no action seems its stuck. I started the process by going...
Hello Humanold,
Please check the following recovery steps:
Full recovery by using recovery partition:
1. Reboot the notebook PC.
2. Keep tapping F11 when the Compaq logo displays.
3. When the Recovery Manager appears, click Next.
4. When prompted to use the Microsoft System Restore program, select No and click Next.
5. When prompted to use the System Recovery, select Yes and click Next.
6. Select the option to perform the recovery without backing up files and click Next.
7. Upon completion of the process, recovery will display "The PC Recovery was successfully completed".
The recovery process will return your PC to the factory image.
Full recovery by using recovery disks:
1. Open the disc drive door and turn off the PC.
2. Insert the first Recovery disc in the disc drive and close the door.
3. Press the power button to turn on the PC.
4. The HP Recovery Manager window appears during the boot process.
If the HP Recovery Manager can access the hard drive, a prompt is displayed to backup the user files before continuing the recovery.
If the HP Recovery Manager cannot access the hard drive to fix the system errors, the HP Recovery Manager will overwrite all the data and reconfigure the entire hard drive to its original condition.
5. Follow the prompts to insert any additional recovery discs in the disc drive.
Sep 10, 2008 | HP Pavilion dv6000z Notebook
WD 5000GB hard drive problems
Click on Start and then right click on My Computer and then click Manage.
On the Computer Management Window, click on Disk Management and then check if there is any uninitialized partition or drive. If you see any such drive, then right click the drive and initialize the drive.
If am not sure but once you do that, you may or may not lose the data.
Feb 22, 2008 | Computers & Internet
Factory settings
If windows still boots ( and the original hard drive is still in the computer) you can click the start button and find the HP Recovery Manager under the All Programs list. It is probably tucked away under one of the HP tabs.
If windows doesn't boot, and you still have the original hard drive you can press F11 when your first turn it on at the HP logo screen. It should start the recovery program. (The F key can be different on different laptops but most recent HP's are F11)
Be careful, doing a System Restore will erase all your Data, so backup anything important!
Nov 13, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv1000 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
