Question about M-Audio Audio Buddy Dual Mic Preamp Microphone
Set up m-audio buddy dual mic preamp
Hi-
I have a m-audio dual preamp; what is the best way to set up with 2 dynamic mics and a boss br1180 studio?
Thanks!
Albion
Ive got a problem cuz this thing doesnt have a ******* firewire port. and i was hopoing to use this for pro tools. i need to know where i can get an adapter of some sorts. but what you should do is hook the mics in to the back ports. adjust volume. then do the ****
Posted on Sep 07, 2008
SOURCE:
I have a lexicon alpha, samsung CO1 condenser mic and a samsung phantom power box, i have all the correct wires but i dont think i am connecting the correctly, HELP ME ! lol
Sorry, but the Alpha does NOT have Phantom power which IS required for a condenser mic.
You will either have to get a mic preamp that supplies phantom power or go to a dynamic type mic if you stay with the Lexicon Alppha.
Jan 17, 2011 | Lexicon Alpha Personal Recording Studio
Basic settings for behringer mic2200
basic would be all dials in the middle. and appropriate switching on/off of (phantom power) +48volts. this option is required for condenser mics but way too strong of a signal for normal dynamic mics,like the shure SM 58. or any non-balanced input
Dec 23, 2010 | Behringer ULTRAGAIN PRO MIC2200 2 Channel...
Im having a problem with hearing my b-1 studio condenser mic on the lexicon alpha progam?
Sorry but... Very simply, you CANNOT use a condenser mic with the Alpha since it does not supply the required Phantom power for the mic. You must step up to another interface to use condenser mics. You can use dynamic mics with the Alpha or other audio sources. I use a Roland/Cakewalk UA25E interface with condenser mics and also the Lexicon Omega which does have Phantom power for the mics..
Nov 03, 2010 | Lexicon Alpha Personal Recording Studio
MXL 990 doesn't work
Your other preamp does not have phantom power to supply power to the microphone. All condensor mics like this need phantom power. The Audio Buddy provides phantom power, which is why it was shipped with those condensor mics
Jan 16, 2009 | M-Audio MXL 990/991 Recording Mic Duo and...
M-audio buddy feedback from mlx 990 condenser mike
Hey I Have These Mics They Work Awesome. But Yes Feedback Is A Problem You Need To Move Away From The Speakers Way Away. Try Lowering Your Highs Or Invest In A Feedback Eliminator They Are Like 89 Bucks But Obviously That Would Almost Cost As Much As The Mic Set. Anyways Feedback Is Made When A Microphone Can Hear Itself Maybe Try Headphone?
Jan 05, 2009 | M-Audio MXL 990/991 Recording Mic Duo and...
How do you connect Audio Buddy to computer
You probably connect the Audio Buddy via a USB or firewire cable. I use both types of audio interfaces. Your mac will sense which bus has audio. Go to System Preferences panel and select sound. Select input. You should see your Audio Buddy listed if it is connected properly. You can set levels from this panel and test the device by looking at the two level meters. Speak into the mic; the level meters should move from left to right. Go to the output panel and chose your monitoring device. I prefer the built-in speakers, but you could also connect your monitor to the USB interface or even the Audio Buddy. If I need better quality monitoring I plug a mini cable into the earphone jack and use a desktop speaker. Don't try to use that headphone jack for anything but monitoring - the quality is not great. If the Audio Buddy software requires that you select an input source, always use USB, never line or built-in mic. Another way to capture audio from an Audio Buddy or similar device is to use Wiretap Studio Pro or Roxio CD Spin Doctor for audio capture. I use both.
Dec 03, 2008 | M-Audio M Audio Audio Buddy Microphone
SETTING LEVELS ON MY POWER MIXER FOR MICING DRUM SET
Go check out these pictures, and there is some good info about micing up your drums. :) Recording it is then a case of getting levels good for a start by worling your way around the kit one drum at a time setting the level for that drum. a bit of nice reverb in the mix and out come you drums.... whoooohhooooo
May 12, 2008 | Samson SX1200 Amplifier
M-Audio Audio Buddy Dual Mic Preamp Microphone Logo
536 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Don Hart
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
