-   Changed batteries, pushed green "Connect" button on bottom, nothing. Replaced with previously-used corded mouse -- which works fine. Any ideas?-   jwd2
Assuming that your keyboard stops working when its on (same for mouse) then it means your machine will be frozen
Try to give it time (around 3 mins) without doing anything letting it resolve the issue the keyboard should work on later. If this solve your problem then your computer is just slow bcoz of a virus, too many programs to load at start up, new software or hardware update.
Try using a different keyboard when yopu boot up preferably a PS/2 keyboard,if this one works well then its means you nmeed to load new drivers for your keyboard and mouse
Also try running chkdsk to clear your harddrive for errors.
Was this helpful?
Yes
No
Solution #2
posted on Mar 29, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i already tried this solution but it is not working. My k/b & mouse (both ps/2) working properly on other system. i dont want to format my hard disk. If there is other better solution pls tell me.
Microsoft's Elite Wireless keyboard and mouse is an excellent combination for use, according to your...
(More)
Microsoft's Elite Wireless keyboard and mouse is an excellent combination for use, according to your criteria. It costs less than $65.00 and is easily connected to replace a wired keyboard and mouse.
I have been using two of them for years now, and have never had a problem with them.
They eliminate excess wires, and work like a charm.
Hi, i have a brand new asus UL50V. i have problems with the keyboard, the text is randomly selected...
(More)
Hi, i have a brand new asus UL50V. i have problems with the keyboard, the text is randomly selected after typing cap T, for instance. Cursor also tends to move to another paragraph for no obvius reasons in the middle of typing. it is very frustrating considering that i've been working on laptops for years and never had this kind of problem before...
Have called Logitech Tech Spt. 12 times with no resolution of problems: i.e.,on sstart up repeated...
(More)
Have called Logitech Tech Spt. 12 times with no resolution of problems: i.e.,on sstart up repeated error message of ''fatal error during installation'' + various mouse functions simply don't work! Running Windows XP 64 it ... downloaded Logitech 64 bit drivers, but appears to me that Logitech drivers are either not up to date or incorrect.
