Question about Ovens
I have a 40 year old Tappan electric wall oven. It has an analog clock with 3 timers on it (2 small timer...stop and start and a large timer with 3 hands on it). Which position do the timers need to be for the oven to come on ? The model # F O V V 226, serial # D133817.
  • 22 Answers
I have one of these too. the TOP small clock should be set to the time you want the oven to start and the BOTTOM small clock should be set to the time you want it to turn off. Be sure to set the oven settings to what you want and the correct temperature.
Try testing it first just to see if it works correctly. It's also important to make sure the other large clock on the oven is set correctly.
Posted on Sep 27, 2010
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Apr 10, 2008 | Smeg SE280X Stainless Steel Electric...
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
Oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do you set the analog clock?
My eaton viking imperial stove came with the house and no manuals. The timers are digial, how do i set them
Oct 20, 2009 | Viking 27" Professional Select Built-in...
Tappan electric wall-oven always says off ????
Check that one of the two hot wires is not losing power due to bad connection. This needs to be checked clear from the breaker to the terminal in the oven. Loss of one side of the 240 volts may still allow the clock to work as long as no other element is on.
OFTEN the connection of to the plug in the wall is bad... IT IS ALSO a fire hazard.
REMEMBER to turn off the breakers when working on this!
Aug 28, 2009 | Tappan 30IN ELEC IGNa Oven
I have a Frigidaire Custom Imperial double oven which still works gret after all these years. But, the clock just died which means the timer doesn't work or the clock to turn the oven on using the timer. I...
A Frigidaire Custom Imperial double wall oven, circa 1966-1970, custom installed into brick wall needs to be replaced, in my home's kitchen. Is there a double wall oven currently available to replace the 1960's which measures less than 21 3/4 in. wide, 443/8 in. high, & 24 1/2 in. deep?
Mar 24, 2009 | Ovens
Preheat worksoven wont bake
hi The range timer is usually located in the control panel on top of the range. If you suspect the timer is faulty, don't try to fix it yourself. Remove it and take it to a professional service person for testing. Here's how to remove the timer:
Step 1: Remove the back service panel to the control panel and release the spring clips that hold it in position, or remove the retaining screws.
Step 2: Push the timer forward to release it.
Step 3: Remove the electrical lead wires from the timer housing. If, when disassembling the timer, you notice that the electrical wire terminals look burned, remove these leads and buff the leads and the terminal points with fine steel wool. Burned and/or dirty terminals can cause the timer to malfunction, but a good cleaning can solve this problem.
Step 4: Replace the old timer or install a new one of the same size and type, if this is necessary. Connect the new timer the same way the old one was connected.
Nov 06, 2008 | Tappan 30IN ELEC IGNa Oven
Wall Oven won't work
I tried randomly pushing 2 buttons at a time, and when I pushed "Timer Off/On" and "Cancel" together it unlocked and is now working fine. The following day it beeped a lot for an hour or so (must have been catching up on previous pushes) but now is back to normal.
Mar 14, 2008 | Tappan 30IN ELEC IGNa Oven
Ovens Logo
486 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
