Question about Samsung SGH-e315
How to unlock my k 800 to format the memory card
After locking memory card, do I then unlock it to take pictures and will that then erase the memory card or can you tell me how to so
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card.
If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Apr 10, 2013 | Cameras
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I want to unlock my micro sd card 2 GB
u can unlock your memory card by the following steps.
Use 2 software phone for unlock the memory card. Use your frinds mobil.
Use a software set(eg nokia 5800, 5233, 5230. 6120c etc)
Insrt the memory card into the software phone
Select setting > data mgr > memory > format memory card...
Its working... Try it..
Note: formating memory card will delet all datas in the memory card.
Sep 21, 2011 | SanDisk 2GB microSD Memory Card
Just purchased a polaroid digital a 800 camera. Trying to take a picture and it keeps telling me card is locked. Alsol said to format sd card but the card is formatted.Cannot take a picture.
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 02, 2011 | Polaroid Cameras
Cant format new 4 mb memory card on PowerShot sd700 is digital elph
If you cannot format the memory card using the format function of the camera, please connect the camera to your computer and use the computer to access your memory card and format fromt the computer.
Alternatively you can also use a memory card reader and connect the memory card to your reader and connect it inturn to your computer and format it from the computer
Dec 25, 2010 | Canon PowerShot SD700 IS Digital ELPH /...
Unable to format the 2GB Memory card. Message occurs : Windows unable to complete the format.
A hidden application is disrupting your format process download "unlocker" software application from google, install it then right click on the memory card icon you find unlocker option double click n press unlock all after this try formating your memory card will work fine
Sep 20, 2010 | SanDisk 2GB microSD Memory Card
Memory card unlock
The way is open your memory card from your phone and insert another phone which also support micro sd memory card. when you insert that then you will see memory card lock unlock memory card. first cancel that and Enter the tools option and go to memory card option. try to format memory card. if format memory card then from your memory remove password. thanks
Jul 08, 2010 | Nokia 5310 Cellular Phone
How do you format a memory card
  1. Insert your memory card into your reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. Step 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. Step 3 Check its contents first to make sure that you have the right drive.
  4. Step 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. Step 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. Step 6
    • Once the process is completed, take the memory card out and insert it into your camera or any other device. Try to browse to it to make sure it works fine now.
    • if this helps please vote
Nov 11, 2009 | SanDisk 2GB microSD Memory Card
My Memory card has locked after formating my Ohone momory.
A standard "unlock code" for memory cards would be something simple like 0000.
Nov 08, 2008 | Nokia N70 Cellular Phone
How to unlock a micro sd memory card
memorey card locked . how to unlock my memorey card tell me
Sep 26, 2008 | Cell Phones
Samsung SGH-e315 Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
