Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Top Draw locked in out position?
Hi After the cycle was finished the draw was pulled out and it seems to have locked itself in the out position. We cant get it to unlock to push the draw in or out?
  • Fisher and P... Master
  • 713 Answers
Sounds like the lid activators havent released. could be the lid activators are faulty or your lid activator control board is faulty.is it a single or double draw? please reply if u need more help to fix the problem
Posted on May 04, 2010
I have a bad draw on my battery on my 85 toyota pickup ive removed the postive battery terminal and placed a volt meter between the positive battery cable and the positive battefy terminal its pulling over...
Had similar draw (not alternator specific) that two auto electrical repair experts diagnosed wrong that turned out to be a stuck starer solenoid that would not full release after cranking. Cleaned the solenoid (very simple and easy) and no more draw.
Could be a bad battery.
Mar 14, 2014 | Toyota Pickup Cars & Trucks
Hi I have a LG front loader washing machine after the was cycle is finished there is still washing powder on the draw and it's gone hard have clean the draw and filters
problem with the water pressor. its should be 5 bar.if its not some remaining detergent you can find end of the cycle.
Dec 15, 2013 | Washing Machines
Cannot unlock draw
Usually a locked draw is caused by an electronic controller failing.To open the draw you can pull it with even firm pressure but do not try and close it as thelid is in the "down "position.Before closing you must go inside chassis by pulling out the affected draw ,unclip the lid motors from the lid supports and push the lid up to the raised position and then wind the arms of the lid motors to the new height,manually and then clip the lid motor arms back into the lid supports.Then replace the draw.Then you must replace the electronic controller...
Jan 06, 2011 | KitchenAid 23 in. KUDD01DPPA Stainless...
3 problems: 1. lower drawer is hard to close; seems to be sticking on something. 2. lower drawer retains water (2 inches) after completing a cycle. 3. F1 fault code on both drawers with alert...
ok where to start, first thing the bottom draw is hard to close because they use 2 little motors on either side to pull a lid with a seal on it down on top of each draw when u start it to keep the water in, if its hard to close the motors are damaged and arnt lifting the lid back up when the cycle finishes making it hard to open and shut, now the F1 fault means the filter circuit board in the base of the machine has been activated basically a flood sensor (and controls minor components ie lid actuators), the unit should beep and flash and go spaztic and you should hear the drain pump come on continuously til u turn it off at the wall thats its way of trying to stop a leak by removing any water it can but will not actually remove the water from the base where the switch is, you will probably find it will work now as the water will have dried and stopped triggering the switch but wont stay like that for long, that machine has major issues its leaking bad from somewhere and id say it leaked onto the lid motors and fried em, the parts you will most probably have to replace is the filter board in the base, both bottom draw lid actuators (small motors), probably the bottom draw lid if you damaged the seal pulling the draw in and out and whatever is leaking and if any other componets where damaged by water, so if its outta warranty id go buy a new 1 with 5 year extended warranty
Oct 26, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
Blockage (i think) top draw - seal orginally locking draw
after you remove the rack you can also remove the large stainless cover( it unscrews, and then under that id the rotor assy , it also unscrews, giving you access to the ports that would be blocked if any, you can refer to your manual for procedure of un-installing above parts if need be, it is something the homeowner is actually advised to do instead of calling for service
Nov 30, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top Draw flashing lights and playing music!?..
this sounds exactly like the problem we had the tech cam out removed the draw and found hte fuse on the heater element was blown -Because the dishwasher was under warrenty he replaced the heater the computer and gave us a new impella
********I'm guessing here but I think you can replace the fuseable resister in the heater element and all will be fine***
Oct 18, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Soap and fabric conditioner draw
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question
Sep 24, 2008 | Zanussi FJS1225W Front Load Washer
Maytag Washing Machine
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Sep 06, 2007 | Washing Machines
Top drawer has no electrical power
I f lock is activated during wash the draw will appear dead when wash cycle finishes ,check for lock symbol in lcd display if it is visible press lock button for about 5 seconds until you hear beep release button and try POWER button
Aug 23, 2007 | Fisher and Paykel 24 in. DD-602 Built-in...
Fabric conditioner still in draw after wash cycle
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 25, 2007 | Zanussi FJD1466S Front Load Washer
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
53 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
