Question about Grohe Model 28 206 OOO: Ladylux Plus Deluxe Champagne shower head - Chrome
Grohe 333 Leaking at the base.
I can pull the handle off my grohe 333 but it is leaking from the base. There is another small hole at the base but it doesn't seem to accept an allen wrench. I could probably pull the cartridge . Do the leaks usually come from the cartridge or where the hose ties into to it. I can't seem to get at the spot where the hose ties into the cartridge. if I pull the cartridge will I be able to get at that spot?
  • 44 Answers
SOURCE: Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Posted on Dec 20, 2008
  • 659 Answers
SOURCE: Grohe ladylux plus is leaking
I believe there is a cartrige that has some washers in the unit. There may be some debris caught in there since it was a little loose. I would turn the water off and disassymble the unit and replace any obvious washers and clean everthing up. Replace it all and try it again. If it still leaks, contact Grohe for more trouble shooting. Faucets have fantastic warranties and companies usually will send replacement parts free of charge at times. Hope this helps.
Posted on Apr 07, 2009
  • 21 Answers
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
Posted on Dec 03, 2009
  • 102 Answers
SOURCE: screw end of cartridge is stripped. handle won't stay on
It sounds like the cartridge will need to be replaced. I would suggest you call around to some of your local plumbing supply houses and see if one stocks or has access to Grohe parts. A good parts man may be able to ID the part over the phone, but you will probably have to take the cartridge in so they can match it up. Stay away drom getting fit-all handles for it, as this is only a temporary fix. Replace the cartridge if possible. I hope this helps.
Posted on May 27, 2010
  • 67 Answers
SOURCE: How to change spray hose on grohe kitchen sink ladylux model
Please see the technical resource at http://www.groheamerica.com/lib/1/tpi/1311421.pdf. This.pdf has an exploded parts diagram that will assist in taking the fixture apart. It looks like the entire fixture has to be disassembled to remove the spray hose. Please let me know if I can be of any further help. Good luck.
Posted on Jul 29, 2010
Bathtub faucet leaking a lot
Change the gaskets.
Popular Grohe 3427 Concetto... Repair Questions - Fixya
www.fixya.com/support/p1162411-grohe_3427_concetto.../popular
Popular Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome questions, problems & fixes. Find expert solutions to common issues, DIY guides, repair ...
Grohe 3427 Concetto Single Hole Bathroom Faucet ... - Fixya
www.fixya.com/search/...grohe_3427_concetto.../grohe_faucet_leaks
Grohe 3427 Concetto Single Hole Bathroom Faucet - Chrome, grohe faucet leaks related issues. Get free help, solutions & advice from top Grohe experts
Nov 04, 2015 | Grohe 3427 Concetto Single Hole Bathroom...
Grohe concetto faucet, 34270, leaking at lever handle when moving lever up and down.
It's a complete cartridge that you need to replace. Contact Grohe and they should send you out a new cart. under their limited lifetime warranty
Feb 16, 2015 | Grohe 3427 Concetto Single Hole Bathroom...
What causes grohe tenso to leak at the body and spout location
Most likey the "O" rings on the spout body are bad, need replacing.
Aug 10, 2014 | Grohe 32924000 Tenso Single-Handle...
My grohe single handle pull-out faucet is leaking. can I fix it myself - I'm a woman that has never done this & the plumber can't come for a week
You need to wait for the plumber to take care of the faucet.
But I will tell you that Grohe has a lifetime warranty on parts.
It would cost you less to tell the plumber to remove the faucet
completely, and take it back to the wholesaler and install a new
one. It takes time, to take a faucet apart, then go get the parts,
then put it back together.
I say again, it's faster to replace a faucet ,than repair it.
And time is money.
All the best to you.
LeRoy
Nov 09, 2010 | Grohe Plumbing
How do you remove the handle son a Grohe two-handle classic style faucet
Pull the handles straight out of the faucet. use both hands to pull back on the hand while wiggling it left and right just a little at a time. Eventually it will pull off.
May 20, 2010 | Grohe Classic Kitchen/Bar Faucet ...
Trying to remove handles on grohe 31054000
I couldn't find the number you have on the Grohe website so I have included a link to their website. Just find your model and it will give you many different options for manuals. Hopefully this will give you the information you are needing.
http://www.grohecatalog.com/category/1/
Apr 12, 2009 | Grohe Plumbing
Apr 06, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
Leaking tub spout single handle volumne/thermostat
See if you can give me a head on picture.
From the top it looks like it could be a Kohler or Grohe.
Thanks,
sanray
Dec 27, 2008 | Plumbing
Grohe Model 28 206 OOO: Ladylux Plus Deluxe Champagne shower head - Chrome Logo
53 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
