Dacor ECD230 Epicure Stainless Steel Electric Double Oven Logo
Posted on Mar 25, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dacor ECD230 Sabbath Mode
How do I activate the Sabbath Mode on the Dacor ECD230 Electric Oven?
  • Bluerock Mar 26, 2008
    Thank you. Do you know if there is a way to set the oven to turn itself off beyond the 11 hours and 50 minutes (plus two hour hold time) that is mentioned in the manual? I need to keep it on for approximately 36 hours and then shut off.
  • Anonymous Mar 28, 2014
    I cannot find the manual to my Amana oven and I want to know how to set the Sabbath mode.
Anonymous
Level 2:
Scholar:
  • Expert 91 Answers
  • Posted on Mar 25, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
91
Questions
0
Helped
70988
Points
213
You don't need to do anything special.
Quoting from Daco.com FAQ
"In our ovens, the cooling and convection fans do not turn off when the oven door opens. The lights also do not turn on. There is no timed shutoff on our ovens, either, meaning that once they are turned on, they will stay on until you manually turn them off. Both of these would be considered violations. Our ovens do not have a special Sabbath button because our ovens already adhere to the laws. When the oven door is opened, there are no changes to the control panel, which would also be a violation. It is best to wait for the small "On" light with the circle around it to go on before opening the oven door, though. This light indicates that the element has gone on, as the oven cycles on and off to maintain the selected temperature. Opening the oven door without this light going on may trigger the element to go on, which can be a violation."
1helpful
What does a beeping sound with F1 symbol mean?
Error F1 means that your Dacor Oven indicates element relay circuit failure. To resolve this issue the control board should be replaced as it has gone bad.
Good luck.
Dacor ECS230 oven cannot set clock. Push clock button nada.
Any display at all? If not then hunt for one of these in the wiring connecting directly to the oven control. Then try to locate the fault such as bad fan etc.2295727.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Bake element
It may have also Blown the Fuse, to the element, in the stove itself.
8helpful
1helpful
Dacor ECD230 lower over won't heat up after cleaning
Under the panel between the ovens there is a little square box with a reset button on it.
2helpful
Double electric oven
This is actually a feature of the oven. Holding the cancel/secure button down for three seconds puts the oven in a locked out mode so that it can't accidentally be turned on. The displays say 'OFF'. Holding the cancel/secure button again for three seconds enables it for use.
Top Dacor Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Ngoro
Are you a Dacor Oven Expert? Answer questions, earn points and help others
