Question about Samsung 932BW Monitor
I have a samsung Syncmaster 932bw and turned it on and noticed a real bad flicker ran all the tests i could find other then your flashlight test cause i dont think it pertains to my certain problem. after messing with it for about an hour i was turning it different directions while still on its stand and noticed when i leaned it one direction the flickering started to slow and eventually stopped, any suggestion before i tear into this monitor on what could be the culprit?
  • Samsung Master
  • 1,684 Answers
The flickering picture usually indicates that the power supply is failing. The most likely cause of the power supply failure like this is capacitors either drying out or bulging from over heating. We have a page on our web site at: http://www.ccl-la.com/blog/index.php/capacitors/ This article wexplains what capacitors are, what you will need to look for to identify the failures and which brand and series to get tof rht replacements. In most cases you can open the monitor and look over the power supply and see obvious bulging on the capacitors that are failing. If you replace them you should be back in business. If you have additional questions just let us know.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on May 01, 2010
Greetings, I have the same problems as lots of people with my Samsung Syncmaster 740N flickering, and suddenly went off. The display can be turned off and on again and it will display shortly and then went...
Use good caps with LOW ESR, you can also have bad lamps which will also cause the inverter circuits to go into shutdown to protect itself. You need test lamps to test that. You may have to check the power supply DC outputs, Inverter circuits for bad transistors, transformers, etc.
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=samsung&megnev2=740&kategoria=monitor&kat2=schematics
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 11, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung syncmaster 204b not turning on- My monitor's problem was when it switched off, the only way to make it work was switching off main power, and turning on again, then it would come back on flickering...
With certain Samsung models, not only do the capacitors go, but the MOSFETS will go as well, possibly a fuse. The MOSFETs are the big bulky black things with a silver tab and three legs. Should be between the capacitors and the transformers. Just pull those both out and test them (Google "test MOSFETS") One is probably bad but they must be replaced in pairs.
Dec 17, 2010 | Samsung SyncMaster 204B (Silver, Black)...
Monitor flickers at start for 20-30 seconds, then everything is ok.
Either a dying backlight or bad internal connection. If under warranty, RMA it with place of purchase. If not, you can try opening it up & tightening any loose connections then reassemble & test. If problem still persists, replace the backlights.
Nov 29, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have owned a Samsung 932BW a couple of years. First symptom noticed was a blank screen and a blinking blue light around the on switch. From another desktop computer, I have swapped video cards,...
reynolds3d, Nothing new here. Happens a lot. 932BW will need to have some work done to the unit's SMPS probably. Read my fixya profile and make decision on what you will do based on info found there. 12fixlouie
Feb 20, 2010 | Samsung SyncMaster 932B LCD Monitor
I am having trouble when I first turn monitor on. I get a flicker of an image and then black screen. I have to do this multiple times and eventually it stays on. Anything I can do?
m_v_schwartz, Best guess is problem with unit's "switch-mode-power-supply" / "CCFL inverter supply" has a bad "cold" or "frosty looking" solder joint (thermally intermittant solder connection) on the printed circuit board!!! Unit WILL NOT fix itself!! Only you or a qualified electronics technician will fix it. Use your warranty first if valid option!!!! See more of my responses to other LCD black screen symptom OWNERS that I have replied to in my fixya profile. Know and understand the "FLASHLIGHT TEST" that every LCD owner should know how to perform when "black screen" shows up. If this response steers you in right direction, please return to rate this response on fixya. FYI, Also visit web sites I have mentioned in the other responses in profile. Good luck with the repair. 12fixlouie
Dec 25, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
When computer is starting up monitor goes blank. I have to turn it off and back on
Sent in for warranty repair to Samsung. Appears there has been some problems with 932B & 932BW.
Nov 30, 2009 | Samsung SyncMaster 932B LCD Monitor
Moniter very lightly flashing
Problem was not solved. I am returning to Samsung. Thanks.
Jan 05, 2009 | X2Gen MG19MY 19" LCD Monitor
SyncMaster 920n Power Cable (?) Issues
I think my monitor power connector broke too
Sep 29, 2007 | Samsung SyncMaster 920N 19" LCD Monitor
Samsung 932BW Monitor Logo
1,290 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
