Question about Canon PIXMA iP3000 InkJet Photo Printer
I have 5 lights flashing on my IP 3000, but when I open the top, the print head does not move to the center. How do I get the print head to move?
  • 286 Answers
SOURCE: Canon Pixma iP4200
When you plug your printer into the computer, what does the computer say?
Count how many flashes you are getting. Look in your owners manual to see what it says for that number of flashes.
Posted on Dec 30, 2007
SOURCE: iP2000 print head won't center
try to unplug the printre while the print assembly is on the middle
Posted on Mar 11, 2008
judesoul
  • 127 Answers
SOURCE: canon ip 3000 photoprinter not working
things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Posted on Feb 07, 2009
  • 4090 Answers
SOURCE: would not print,
This is a waste ink code and needs to be reset. follow instructions below.
Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Posted on Nov 24, 2009
  • 739 Answers
SOURCE: Canon iP 5200 orange light flashing 5 times
Hi
IO have one of these printers as my daily workhorse. Thankfully I haven't had the problem you are having.
Did you remove the print-head from the printer and clean it with running warm water?
When I get a possible print-head problem I always do that, rinse it until the water runs clean. Then dry it on kitchen roll making sure that the contact on the back are completely dry before refitting it to the printer. Generally this has cleared any problems (I have several Canon printers - I'm not just referring to the 5200 now).
However If you still get the error it may be worth contacting your nearest Canon service centre. New print-heads are not exactly cheap but these printers are so good it's worth keeping it going. They will probably be able to diagnose the problem quickly and accurately and tell you if it is cost-effective to repair. I don't know what would be involved with the Eprom error. - probably a circuit board change inside the printer.
Posted on Dec 22, 2009
Printer fault
The Canon Pixma IP 4000 printer has a self-diagnosing print head error notification system. Generally the "Alarm/Power" light will flash and tell you what kind of problem you might be having with your print head.
You can also run tests yourself to identify problems.
Look at the "Alarm/Power" light and see how many times it's flashing.
If it flashes orange 11 times consecutively, that means there is a print head alignment issue. Perform deep cleaning, then move the printer away from any strong light sources.
To deep clean, click the Maintenance tab in the "Printers" folder.
Then click the "Deep Cleaning" icon. You can select all colors, black, or selected colors. Click on "Execute."
If it flashes orange five times consecutively, that means there is a print head error.
Reseat the print head, then reset the printer.
To reseat the print head, make sure the printer is on.
Open the paper output tray and top cover.
Make sure the print head holder is in the center and open the inner cover. remove all the ink tanks.
Raise the print head lock lever and remove the print head.
Reseat the print head and lock the lever.
Replace the ink tanks.
Check to see if the ink is ejecting normally from the print head nozzles by running a test.
Press and hold the "Resume/cancel" button.
When the Power lamp flashes twice, release the button.
Examine the printed output.
Use the references below to compare your output to what Canon suggest is correct.
If the output is incorrect, then perform deep cleaning, if necessary repeat twice.
Replace the ink tanks if you're unable to get a good result by following the previous steps. make sure the printer is on, lift the top cover.
The print head holder will move to the center.
Press on the tab to release the tank.
Unwrap a new tank.
Make sure you can see the air hole and insert the new tank until you hear a firm click.
Repeat for the other tanks if you suspect from your print test that they have failed.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10239 - SupportDetailAct
Apr 23, 2013 | Office Equipment & Supplies
Canon Printer i550 Printer will not start, but warning light flashes green/yellow green etc. Flashing does not stop if press right hand button Flashing still goes on after re-installing printer...
this is the service error for this you have to reset ink counter, it's available on your manual.
or you can use utility like ip tools available free on net
Oct 13, 2008 | Canon Office Equipment & Supplies
5 yellow blinks and nobody else ,
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Reseat the print head iP3000
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove all ink tanks
  5. .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Solution: 2 Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Aug 30, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Just stopped working, orange light flashing
  • If it flashes orange five times consecutively, that means there is a print head error.
  • Reseat the print head, then reset the printer.
  • To reseat the print head, make sure the printer is on.
  • Open the paper output tray and top cover.
  • Make sure the print head holder is in the center and open the inner cover.
  • Remove all the ink tanks.
  • Raise the print head lock lever and remove the print head.
  • Reseat the print head and lock the lever.
  • Replace the ink tanks.
Jan 30, 2011 | Canon Pixma iP4500 InkJet Printer
I keep getting a service error B200, and the lights flash green and orange alternately. How can I fix this?
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Jun 07, 2010 | Canon PIXMA iP4600 Color InkJet Photo...
5 orange flashes
5 time orange flash indicate Cartridge Error or Print Head Error.
1) Reseat the Print Head
  • Confirm that the printer is powered on.
  • Open the paper output tray and top cover. Gently open the paper output tray while holding it.
  • After confirming that the print head holder has moved to the center, open the inner cover.
  • Remove all ink tanks.
  • Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
  • Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
  • Close the inner cover and top cover. Check that each ink tank is installed in the correct position.
2) Reseat the Printer
  • Turn the printer off with the Power button.
  • Disconnect the data cable from the printer
  • Unplug the printer's power cord for approx. 10 minutes, and then plug it back in.
  • Turn the printer back on.
Else either your device require service or print head may need to replace.
Good luck...don't forget to rate the solution
Feb 25, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Ip 5300 error b200 10 blink orange-green
Sep 26, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
Canon S520 printer stopped printing has 7 orange lights before the green light on printer has an error code
Hi ...
light flashing 7 times means that there is an issue with printer head. Try and perform the below steps to reset the printer head whcih might resolve the problem. If this doen not, I would suggest you get your printer checked by a technician.
  2. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
  3. Hold and slowly move the print head lock lever up and down several times.
  4. Lower the print head lock lever to secure the print head.
    Note: Holding the print head may cause it to not be seated properly. Perform this step using only the print head lock lever.
  5. Close the front cover.
Don't forget to vote if this helps ... Cheers :)
Aug 05, 2009 | Canon Office Equipment & Supplies
Canon ip5300 b200 error message unplugged and replugged lights still flashing between green and orange pulled all printer cartridges no resolve
Jun 16, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Orange lights (3)
Three orange flashes between green indicates a paper jam on this model. Look closely in the paper feed area and the paper exit area for any torn scraps of paper. Also open the top and check in the platen area (where the print head moves back and forth). If you don't see anything, it's possible that a sensor has broken or gone bad.
Jun 11, 2008 | Canon BJC 3000 InkJet Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
old marine
old marine
