Question about DeLonghi DE500P Dehumidifier
I lost my product manual. Can you help me turn the unit on?
  • 8,197 Answers
To turn the product on just push the stand by button. If you would like the manual it is on the link below just type in the #'s then click on download to get it. Give it some time to download.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good Luck and please rate 4 thumbs up for the free answer. If you have any questions please ask befor you rate.
Posted on May 01, 2010
How do I set the humidity % on my dehumidifier? I lost the User Manual and the unit is not collecting water after running for hours. Make: Airworks - Model: A1DMDA10AG
If you have an LED screen on your unit, lower (arrow down) the humidity extraction level to 35 - 40%. If you have an analog unit, turn the humidity extraction knob to Maximum (which should be clockwise).
Hope this helped you and thanks for choosing FixYa.
Aug 15, 2011 | Dehumidifiers
My lg DEHUMIDIFIER model #LHD65EBL is no taking in any water. Cleaned the filter and coils.Installed the basket properly.Set the setting at 35 to70 and nothing happens. just runs. About 4 years old.
According to your Owner's Manual. once the humidity extraction level is set at 35%, you should push the minus (-) key one more time to turn the unit ON. It will now run continuously no matter what the humidity level is until the bucket is full.
In case you have misplaced your Owner's Manual, go to the link below and click on English. The Owner's Manual will download and you may print it for future reference.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LHD65EBLY8&matchedModelCode=NOT_MATCHED&searchEngineModelCode=LHD65EBLY8&targetPage=support-product-profile&initialTab=documents#
I hope this helped you solve the problem.
Jul 19, 2011 | LG Dehumidifiers
I lost the instructions and want to set up a direct drain, however, I don't remember what settings are what...ie fan, the hour glass thing, or how to set the house temperature...help!
Here is a link to the Owner's Manual for your model dehumidifier. You can download and print the manual for future reference. I would encourage you to keep it in a safe, accessible place, as your model has been discontinued. Which also, mean take good are of your unit and do routine maintenance on it. That will add to the longevity to it's use.
http://www.danby.ca/cms/uploads/products/en_manual/DDR586R%20EFOM.pdf
Hope this helps you get the constant drainage hooked up properly.
Jul 13, 2011 | Danby DDR586R Dehumidifier
I have a Haier DE65EA Model and I turn it on, but then it shuts off after about 30 seconds. The bucket is not full. I have lost the owners manual for it.
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Your particular model has been retired. However, the Owner's Manual for the replacement (much like yours) is available at the following link. http://www.haieramerica.com/en/asset/product/31b6415af4
You can download & print it for future reference.
I hope this helped you to troubleshoot & solve the problem.
Jul 11, 2011 | Haier 65-Pint Dehumidifier
Flashing green light stays on, unit won't start when you press the on/off button
I believe the unit needs to me reset to the manufacturer's default settings. To do this, turn the Master ON/OFF Switch to OFF and unplug the unit from the outlet for 10 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. The green light will blink until you change the humidity setting to below what the humidity level is in your home. If you set it higher, it will not turn ON or will turn ON only for a couple of minutes.
Also, check the position of the water collection bucket, to make sure that it's installed properly and has triggered the safety device.
To help you more, I have included a link to your Owners Manual that you can download and print for future reference, if you have misplaced yours. Take good care of your unit and perform routine maintenance regularly. As Danby has discontinued (retired) your model humidifier.
http://www.danby.ca/cms/uploads/products/en_manual/DDR4007EE2.pdf
Hope this helped you. Please let me know. Thanks.
May 06, 2011 | Danby DDR4007EE Dehumidifier
Hi, When I tried to start my dehumidifier, it won't work and indicate CH 01. The bucket is totally empty and in good place. What this CH 01 means?
Your model is no longer in manufacture or available. However, I was able to locate the Owners Manual for you. It does not list a CH 01 Error Code, but does list other reasons why your unit want turn ON.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LHD45EL&matchedModelCode=1000001989&searchEngineModelCode=LHD45EL&targetPage=support-product-profile&initialTab=documents#
In the past, I have recommended turning the Master ON/OFF Switch to OFF and unplugging the unit for 12-15 minutes. This will give the unit time to hopefully, reset itself. Then Plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity control as you normally would. If it successfully reset itself, it should operate normally.
If you continue to have problems, contact LG Customer Support at 800-243-0000.
Hope this helped you to solve the problem.
Apr 14, 2011 | LG LHD45EL Dehumidifier
AIRFORCE CLIMATE CONTROL HIGH PERFORMANCE 20 LITRE A DAY DEHUMIDIFIER WDDH-820EAH - Hello can you provide me with basic instructions for this as i have lost my manual. Thanks
Hi and welcome to FixYa, I am Kelly.
Per the model number you provided in your post (WDDH-820EAH) this is your user's Manual:
http://www.orientalpacific.com/backend/files/products/manuals/127/WDH-820EAH%20User%20Manual.pdf
Note the comment about air filter cleaning on the back of the unit every 2 weeks.
Thanks for choosing FixYa,
Kelly
Dec 27, 2010 | Dehumidifiers
I lost my manual can you help me turn the unit on- I can't remember what settings to use?
You can get the manual on the link below. Just type in the # code then click on download now. This is for the DeLonghi DE500P If that is not your model please give the make and model #
Good Luck and please rate.
Jun 12, 2010 | DeLonghi DE500P Dehumidifier
Noise
Based on the information provided above, I am unable to provide a positive solution to your issue. I have provided some common solutions to help guide you in your search.
Most dehumidifiers have access to the fan through the front.
Below is a link to download pdf.format user's manuals. You must register to access the information, (free). You will need the information off the product data tag, then enter:
Type of product
Brand Name
Model Number
http://www.managemyhome.com/mmh/products/ManualSearchDisplay.action?product.productName=Washer+-+clothes&product.brandName=maytag&product.modelNumber=mah3000ayw
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 11, 2008 | Kenmore 54701 Dehumidifier
DeLonghi DE500P Dehumidifier Logo
251 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
