Question about GE WPXH214A Front Load Washer
WONT SPIN ON ANY CYCLE A FLAT BLACK PLATIC PIECE CAME FROM LATCH
MY WASHER IS A STACKED DRYER ON TOP MADE AWFUL NOISE WHEN SPIN CYCLE WAS GOING I LIFTED TOP OF WAHER LID AND THE FLAT PLASTIC LATCKER I ASSUME BROKE THE WAHER I TITLTED IT TTHINKING THAT WOULD STOP THE NOISE BUT IT WONT SPIN AT ALL NOW WILL GO THROUGH ALL OTHER CYCLES EXCEPT SPIN ?NOT MINE ITS THE LANDLORDS
  • 438 Answers
Well the land lord is responsible to repair or replace a unit(appliance) that is offered in the rental agreement ,,this is his problem assuming that you did not abuse your machine IE kids taking a ride in it, filling the washer to the point the lid dos not close and so on lol i`m certain you are innocent of this,,,,,,,Right ?
at any rate coordinate your efforts to repair your unit with your landlord, i`m certain that any good landlord will be reluctant but obliged to have this situation ratified landlord ,,,,,your fault is most likly with the lid switch it is a safety feature built into all washing mashines to prevent the spining action to ocer with the lid oppen this is to provide a prevention to personal phisical injeries
Posted on May 01, 2010
Washer wont drain
Hello shirley_dods - Is the washer making a humming noise? If so, either the drain hose or pump is clogged and needs cleaning. Try setting the cycle to spin cycle only. Will water pump out? If it does not, then the washer could possibly be experiencing a communication error with the control board, faulty pump, timer or door lock assembly. At this point, I recommend connecting with a professional to accurately pinpoint any potentially more serious issues.
Mar 04, 2013 | Frigidaire FEX831CS Top Load Stacked...
We installed a stacked set of WFW9250WW and WGD9270XW Whirlpool washer and dryer. When we turned on the washer, everything worked fine until the spin cycle. The machine started vibrating violently and...
Hello, welcome to FixYa.
I understand you have a problem with your stacked washer & dryer, thank you for providing the model number (of both) that is a good start... however I need to follow that up with a couple of questions.
Are these "new to you" machines or have you had them prior to this and just never stacked ?
Also had you run the washer before they where stacked and not noticed an vibrations violently/noise like a hammer spinning inside?
Finally, what method did you use to fasten the dryer to the top of the washer and did you remove the cabinet top of the washer before stacking...for the record it should not be removed as was the case with some other manufactured machines.
Let me know if you can add anything further along with the make & model. I will wait for your reply to move forward.
Thank you for choosing FixYa.
Regards,
Macmarkus :)
Jul 13, 2011 | Whirlpool Washing Machines
Washer fills and does the wash cycle then stops. doesnt rinse or spin
Most likely your lid switch is broken on the washer. I(t acts as a safety mechanism to stop the tub during spin should you open the lid.)
The switch is located under the top of the washer on the right side of the lid opening. It is activated by a plastic strike on the same side of the lid.
Jun 12, 2010 | Whirlpool LTE6234D Top Load Stacked...
Won't spin, makes clunking noise, drains fine
If it agitates fine , with normal noise , drains with lid closed , then the problem is probably the transmission .
Aug 02, 2009 | Kenmore 24032\24036 Top Load Washer
My stackable whirlpool washer doesn't spin/work
The most likely cause is the motor coupling , its the plastic and rubber parts between the motor and transmission. Try turnig it with your finger.
Mar 11, 2009 | Whirlpool LTE5243D Top Load Stacked...
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
GE WPXH214A Front Load Washer Logo
99 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
