Question about Home
Bathtub takes 3 mins to start draining. The drain is not clogged. After about 4'' of water the tub starts to drain and drains fast, but won't even attempt to drain until about 4'' full. Same thing everytime. Is my 1 1/2'' drain too small? Do I have a venting issue? Same happened in old house I changed to 2'' pvc and it never happened again, but is it normal to need 2'' pvc?
  • 2,100 Answers
Might be the problem, especially when you can't get to those pipes, always use 2 inch. If you had a vent problem, the water would gurgle out very slow, and the toilet wouldn't flush. The 2 inch trap at the tub is a must, it will never clog, and you shouldn't have to worry about it. I'm surprised that they built it that way. Most drain lines are 3 inch with a vent at the farthest point, so all the smaller lines would be 2 inch all the way to the roof except for the p-traps at the sinks. Hope this helps.
Posted on May 01, 2010
Testimonial: "Thank you that helps a lot. "
The tub is clogged with hair
Few plumbing issues such as Dripping faucets. Running toilets. Leaky valves. Clogged bathtubs can be solved by our own trying few things.
1)Firstly lookout for what is causing blockage such as soap or hair inside the pipeline blocking water just pull it out from pipes.
2)Secondly use a plunger(Tool used by plumber to clear clog) pour some water in bathtub to cover the plunger block the overflow of water with rag.Place the plunger over drain pull up & down 5 to 6 times.
3)Lastly if still the clog is not cleared try out with snake a long flexible steel cable wound on a handle In a sink you just feed the snake down the drain, but on a bathtub you need to feed the snake down through the overflow plate opening. Start by feeding about 3 feet of the snake into the opening, turning it as you push it forward. You will feel some resistance as you work the snake through the trap under the drain, and the turning helps to move the head through the trap. The snake should either break up the clog by pushing its way through it, or your turning will hook the end of the snake onto the clog and you can pull it out.
After trying with above if still there is plumbing issue call sewer line repair services for help.
Grease Trap Services
May 03, 2015 | Maax Home
Not draining the tub
To my knowledge, most problems such as one you have can be caused by three (3) possibilities:
1. electronic - the activating circuitry that engages the drain valve is faulty;
2. electrical - the drain valve is not opening evening if electronically activated; and
3. mechanical - the drain valve is stuck or the most likely, the drain passageway is clogged.
The last would be your best option and possibly the easiest to correct.
To recap, you hear a clicking sound means that the drain valve opens, you hear the motor, means the drain motor is running, but no water drains out, that only leaves a clogged system.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 11, 2008 | Whirlpool GSX9885J Top Load Washer
Gurgling in the bath tub when toilet is flushed
follow this steps and fix it. God bless you
lear a clogged (not stopped) sink or bathtub with a plunger:
  1. If you have a dishwasher, pinch off the rubber dishwasher drain hose that leads to the garbage disposer using a clamp or locking pliers. If clearing a bathtub, remove the drain stopper and cover the overflow opening with a wet rag.
  2. Remove the sink basket or tub stopper and clean any debris from the drain opening.
  3. Fill the sink or tub with sufficient water to cover the plunger cup, usually about 2 inches. If you are working on a double sink, seal the other sink with a stopper so the plunger can create a vacuum.
  4. Set the plunger on the drain opening and repeatedly pump it up and down, then pull away sharply to dislodge debris. Repeat if necessary.
  5. Turn on warm or hot water to flush loosened debris from the drain.
  6. If the clog remains, use an auger (see below) or an expansion nozzle (see below) to clear the drain.
Clear a clog using an auger:
  1. Remove the stopper or strainer. If unable to do so, disassemble the drain trap (see below) and feed the auger directly through the pipe. Make sure you have a pail and rags nearby in case of a water spill.
  2. Release the setscrew on the auger and begin feeding the cable into the open drain.
  3. Once the auger tip hits the clog, set the screw and crank the auger clockwise to break up the clog.
  4. Continue breaking up the clog and moving it down the drain line with the auger. Once there is no more resistance to forward motion of the auger, stop and carefully remove the auger.
  5. If the clog can't be moved, continue twisting the auger to possibly snag and retract the clog.
  6. Once the clog is cleared, flush the drain with boiling water.
Nov 04, 2013 | Plumbing
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
Toilet bubbles when tub drains could be from stuck toy in tub overflow?
The bubbling sounds like it's trying to get the air it needs to drain. Kind of like holding your finger over thr the top of a drinking straw and then lifting it out of the water. The water won't drain out until you lift your finger off the straw, allowing air to come in so the water can drain out. If the vent is clogged it could cause this. Squirrels dropped walnuts down mine and clogged it. The vent is the pipe that goes up through the roof, nearest to the toilet and shower. If the shower drain vent line is clogged it is possible that it could be sucking the air it needs through the toilet, sometimes actualling pulling the water out of the toilet. This is not very common but it can happen. If you can get on the roof and get a garden hose into the vent line(s), you can tell if it is clogged because water won't drain, it will come back out. You should be able to turn the water on full blast and it will drain normally if the vent is clear. It's possible that there is a connection between the toys and your problem, and the way you access that drain line is usually thru the wall on the opposite side of the shower controls/drain. I would start by running water down the vent lines on the roof. Good luck.
May 02, 2012 | Home
Hi My toilet back up so I plunged it ,water went down, then once filled clean water bubbled in toilet, then nasty toilet water started coming in my bathtub which sits next to it. I have now plunged &...
If water is backing up into the tub then you have clog downstream from that bathroom group. If water backs up when you ran water in the rest of the house then you have a clogged sewer service. With either case the house drain and / or sewer drain will need to be snaked. Most of the time it will be the sewer drain.
Jan 18, 2011 | Plumb Pak 1-3/8 Bath Waste/Overflow Assy...
My Reliance 606 40 gallon water heater only heats up enough hot water to fill a bathtub. We've drained it, the pilot light is fine, it heats up the water really hot, but it just doesn't seem to be able to...
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Jan 04, 2010 | RELIANCE ELECTRIC WATER HEATER
My bathtub drain leaks. Is there a product to
No, not without sealing, I mean clogging, the drain. Do you know exactly where the leak is coming from? I would suspect that the water is getting around the drain, instead of down the drain. The visible part of the drain should unscrew from the part that is underneath. That bottom part is likely permanently sealed to your drain plumbing.
You may be able to easily fix your leak by:
#1 Unscrewing the visible drain top.
#2 Replacing the washer under that top. This will seal your tub to your drain. All water will then be forced to flow down the drain properly.
#3 Screw the top of your drain back into place WITHOUT folding or wrinkling the new washer.
Good luck
Jan 03, 2010 | Kohler 1221-H-0 Seadream 6' Whirlpool Bath...
Home Logo
104 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
