Question about Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ...
Low pressure to the main faucet, great pressure to the side spray
I have a price pfister and water drips from the main faucet but the side spray I get great water pressure. Help!
  • 4 Answers
The problem is your diverter valve. It was a poor design. You can buy a redesigned replacement for under 10 bucks. Look up your faucet on plumbingwarehouse.com and you will find the new part. It takes two minutes to install.
Posted on Nov 17, 2011
    Sergeant:
    Champion:
  • 333 Answers
Try un-screwing the screen on the end where the water comes out. Could be clogged
Posted on May 01, 2010
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
We have a new Price Pfister 49 Series bathroom faucet set with two handles. Even with the hot water tap open full the water just dribbles out
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
Mar 07, 2011 | Price Pfister Two Handle Lavatory Faucet -...
I have a two handled price pfister kitchen faucet and replaced the cartridges and now have low water pressure what did i do wrong?
probably the diverter, order from mfg & replace or you can disassemble diverter and replace internal white part and O ring which is what I did and worked great
Oct 04, 2010 | Price Pfister Plumbing
Fix diverter valve sprayer No water pressure Can I soak in CLR? Where to buy Parts ?
CLR usually works great. Replacement parts are available at Lowes Home supply stores and perhaps Home Depot. I've had better luck getting parts at Lowes.
Mar 09, 2010 | Price Pfister Marielle Kitchen Faucet with...
Water runs slow
Three possible reasons for low pressure. 1. faucet cartridge has debris in valve body. 2. aerator has debris ,just unscrew and clean out. 3. Water valves under sink are not opened up. hope this helps
Jul 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
Kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
May 04, 2009 | Price Pfister J103-BC 100 Series Kitchen...
We cleaned our price pfister faucet because we had low cold water pressure - when we hooked it back up and put the handle back on the water will not turn off.
You more then likely replaced the diverter washer backwards. There is a washer/gasket that has multiple holes (2 or 3) and it is probably just rotated 180 clockwise (or counter).
There are very few moving parts in a faucet so this should fix it.
Apr 13, 2009 | Price Pfister 34-3LC Genesis Kitchen...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Price Pfister Marielle Kitchen Faucet with Matching Spray and Soap ... Logo
635 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
