Question about Frigidaire ATF6000ES Front Load Washer
The message of the machine is code dr could you
The message of the machine is code dr could you tell me what means this code. thank you
  • 438 Answers
This code says to you that the door is not secure, the switch in the door panel is defective and not sensing the door being closed properly there will be no operations of this machine until this is corrected
Posted on May 01, 2010
I have a Frigidaire front loader washer model number LTF7000EGO and it was washing fine then started a beeping noise with dr flashing. What does that mean?
Hello friend, thank you for your post!
I understand that your Frigidaire washer, LTF7000EG0, is displaying a "DR" error code. "DR" stands for door which means a problem with your door it could be an issue with the door latch assembly or door strike. I would suggest resetting your washer and you can do that by unplugging the power cord or flipping the household circuit breaker for ten minutes.
If you continue to experience an issue with the error code "DR" I would recommend reaching out to a professional technician for proper diagnosis and repair. I hope this information has been helpful. -Matt
Oct 09, 2014 | Washing Machines
What is the sequence to start diagnostics running on my Kenmore Elite washer #417.41102000?
DR means that there is a problem with the door. It might be the switch that tells the machine the door is closed all the way
Sep 11, 2014 | Washing Machines
I have a self cleaning kenmore stove and I cleaned it today. It cleaned beautifully, but when it finished cleaning the clock did not come on; a code DR came on. I looked in my manual and could not...
My mother cleaned her oven this weekend and she got the same message on her display. I could not answer what 'dr' stands for, but I was able to clear the message simply by unplugging and replugging the range.
Still if anyone know what it means, it would be a big help.
Sep 09, 2010 | Kenmore Kitchen Ranges
Washer will not start. Getting "dr" message . Door lock light is not lit. Tried cancel and restart tried unplug and restart still getting dr message
The 'dr' error code stands for 'door switch is not closed'. If the door is closed properly, then you will have to replace the door switch assebly.
Hope this helps!
Jun 25, 2010 | Washing Machines
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Error code
'dr' is an error code that indicates the door is not closed. If closing properly the door lock may have to be replaced.
Jun 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Not responding after flashing "loading" for 1 minute then get message R-Lk --:-- on display
Hard drive issue or power supply. Power supply prone to bad capacitors (look for leakage/swollen tops)
If hard drive faulty you'll need a new one which is no small task. Disk contains firmware and custom file system and smallest I've got image is 10.7gig
Feb 02, 2008 | JVC DR-MH30S DVD Recorder
I need the 3-digit setup Code for Trutech T650-DR DVD
Note: In order for you to watch your TV your TruTech T650-DR must be on. Not shure what you mean by code? but setup go,s like this.
Out DISHNET to in on your Trutech T650-DR
Out TruTech T650-DR to in TV Note: the name of the input on your TV video 1 or video 2.
Just like your DISHNET you need to be on Ch 3 or 4 what ever is open.
turn on your DISHNET and your Trutech T650-DR Do you see a Trutech logo on your TV?
If yes, Keep pressing the source Button on your Trutech T650-DR remote Tell you have a TV Ch. then press the return button.
use your DISHNET remote to watch your tv.
thats it hope I could help.
Jan 31, 2008 | TruTech T650-DR DVD Recorder
Frigidaire ATF6000ES Front Load Washer Logo
91 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
