Question about Mantis 2-Cycle Tiller
CAN THE SPRING BE REWOUND ON MY MANTIS TILLER THE CORD BROKE, AND WHEN I WENT TO RE INSTALL THE SPRING CAME OUT
How to re wind spring on a mantis tiller
Posted on Jul 10, 2011
  • 29 Answers
Go to your local small engine supply store with the model an serial numbers. you can buy the spring all ready wound and in a metal container that will drop right in and you will be set togo.
Posted on May 01, 2010
The plug prong broke on my Electrolux Epic 6500 SR vacuum. I cut it off and was going to replace it with a new plug. However, I mistakenly rewound the cord and it went all the way into the body.
You will likely have to install a new cord reel. Cord reels have a long tightly wound steel spring which can fly out causing injury if you attempt to take it apart.
Mar 04, 2017 | Vacuums
MANTIS tiller 7225-00-02 starter cord won't retract
take the crank rope cover off and in between rope reel and cover there is a wind up spring either its broke or has come out of its slots.
Aug 16, 2012 | Mantis Garden
MANTIS 7225-00-02 cord won't retract
sounds like the spring broke or got stuck
Aug 16, 2012 | Garden
I had to replace the rope on my Mantis and cant figure out how to get the spring back in , Help ??
This can be a difficult job for the inexperienced. It can also be potentially dangerous if the spring pops out while you are trying to install it. My advice. Take it to a small engine repair shop and save yourself the headache. Cost should not exceed $20.00.
May 22, 2011 | Mantis 2-Cycle Tiller
My pull cord will not retract
The coil spring has either broken or come loose inside the pull rope housing. You must disassemble the housing to fix it.
Jim
Aug 31, 2010 | Mantis 2-Cycle Tiller
Trying to put on pull cord on tiller.
you remove the cover, bend three tabs and the wheel will come out. Replace the cord in the manner that it is removed, rewind spring and install wheel, then bend the tabs back down.
Jun 22, 2009 | Mantis 4-Cycle Tiller
Spring replacement
Replacing the spring on this tiller can be tough. You have to get the tension spring set into the stop and partially wind the tension (by turning the cord pulley) and THEN attach the cord before completing winding the tension spring. It took me about an hour to figure out how much preset of tension was needed before I was able to get it to work. You have to partially preset tension because starting from zero will not fully rewind the cord.
May 23, 2009 | Mantis Little Wonder Tiller/Cultivator...
Pull cored
You'll probably have to bring it to the repair shop, before that, you may try to remove the cage where the rope is coiled in normally and see if the knot is there, and then get some new rope, match the length, make a new knot, well you get my drift.
May 06, 2009 | Mantis 2-Cycle Tiller
Handle ripped off Mantis tiller
Good job on the cord replacement. Most people take the cover off the spring and then find out it is nearly impossible to get the spring tension set. I have personally repaired dozens of these cords that have been messed up by owners that did that.
If anyone has this problem, just do what this post says...remove the assembly and turn the pulley until you can get to the part of the cord that is broken...grab the end that is broken after you get it out of the opening with a vise grip and pull the cord out fully and lock the recoil spring with a vise or vise grip (but don't crush it)...then replace the cord and hold the end of the cord pull fully extended and remove the lock and allow the spring to recoil...and reinstall the assembly.
Simple, but THINK before you take the housing apart. It is REALLY TOUGH to reset spring tension properly.
Apr 26, 2009 | Mantis 2-Cycle Tiller
Pull cord stuck
it sounds like the recoil spring in the "housing" is jammed( or something is broken) youll have to take this apart without breaking it. you may have internal engine damage if it was unusually hot and the pullcord jammed. try using a richer oil mixture for fuel also if you fix the pullcord. hope this helps, keep me posted.
Apr 18, 2009 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
350 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
