Question about Cell Phones
I need the factory reset code for my Huawei m750
Model number hb5a2h
meid hex:a000001a89e1d8
meid dec 268435458609036248
s/n xe9mab19b2405603
I need the unlock code for my phone
HUAWEI u7510
imei: 357397031402778
Posted on Aug 25, 2010
How do I do a factory reset on my boost motorola android phone, I don't remember my passcode for the swipe thing to get into my phone so I can factory reset it. It is a boost Motorola android? the ba
Seems that you will have to take it to a proper phone shop. They can try to restore it there, but if not, they may have to send it away. There is nothing you personally can do without your code. Hope that this helps and good luck
Dec 23, 2014 | Motorola Mobility I940 Nextel Boost Mobile...
How do I unlock my Huawei M867? MEID(HEX) - a000004247dff9 MEID(DEC) - 268435462604710393
Whats your exact Huawei model ? do you want to unlock your Huawei from network lock ? If so, use unlock code to unlock it . You can get it from any of the online vendors like SimpleUnlocking.com to unlock it .
Oct 24, 2014 | Cell Phones
How can I find my meid number the sticker is off I use Samsung m620
To find the Mobile Equipment Identifier (MEID) on your device, following the steps below:
  1. From the Home screen, touch Applications app_icon.gif > Settings > About phone > Status.
  2. The MEID is provided in two formats:
    • Dec: Decimal number
    • Hex: Hexadecimal number
    NOTE: If your number contains a 0, it is the number 0 (zero).
Sep 16, 2014 | Cell Phones
How do i recover the dec number cause the sticker is off for w385
*#06# may or may not work. The feature was not added to all Motorola phones until after the w385 was in production. You can also find a website that will convert the MEID into a DEC number. The ESN is not a DEC if it has letters. DEC is only numbers and should start with 26. MEID and ESN or HEX have a mix of letters and numbers. There are converter websites if you find the MEID to convert into DEC. Motorola has one too. I'll find it.
Nov 15, 2012 | Motorola Mobility W385 Cellular Phone
Can u convert imei to esn dec or hex?
I can convert IMEI to ESN or ESN to MEID
iflash2metropcs@gmaildotcom
Aug 14, 2012 | Motorola Lands Phones
Isamsung glyde phone locked in nav 2 mode
I'm not sure if this is really necessary for anything other than Samsung phones, but I've only ever seen this issue come up when dealing with Samsung phones. Here's a scenario: You're messing around with the various settings in your phone's menu, and you switch your phone to NAM2 in the process. Your phone resets, and you find that your phone is now locked. Unfortunately, your normal lock code doesn't work. What do you do?
First off, you should probably understand what NAM1 and NAM2 are. Basically, think of them as containers. Each of these "containers" holds a phone number. Yes, you can have two phone numbers on a single cell phone. I generally don't recommend it, though, as you can only have one of the two numbers active on the phone at any given time, meaning that you'll miss all of your calls on the number whose NAM you're not on at the moment. Also, NAM2 generally can't accept over-the-air programming, so you'll need to manually program your account information into it, and you'll need to have updated roaming information loaded into your phone in one of your carrier's retail stores (assuming that they even support NAM2).
So, why am I telling you about NAM1 and NAM2? Well, your default lock code (assuming that you never specified your own) is generally going to be the last four digits of your phone number. Problem is, NAM2 doesn't have a phone number in it by default, so you'll need to somehow figure out what the default lock code is set to on NAM2.
Secondly, you'll need to locate a hexadecimal code, usually found inside of your phone's battery compartment. There are two different types of hexadecimal codes that you'll need to be on the lookout for: ESN and MEID. Now, Samsung phones generally don't have these numbers labeled, but it's easy enough to find them. An ESN in HEX format will be eight characters long, whereas an MEID in HEX format will be fourteen characters long. MEID's tend to begin with the letter A from my experience.
Now, depending on which type of hexadecimal code you found in the previous step, you'll need to take one of two different paths in determining your unlock code...
Let's start with the easier path, the ESN...
Thankfully, all you need for this one is a scientific calculator. If you're using Windows, then simply launch Calculator. Once you've launched Calculator, you'll want to choose View > Scientific from the menu bar.
Once you're in scientific mode, click on the Hex radio button, then enter the eight-character ESN.
Now, click on the Dec radio button to convert your ESN into DEC format. Now, do bear in mind that this won't be the same as the ESN number in DEC format on your phone's battery compartment label. That's why only the ESN in HEX format is important. Anyway, the last four digits of the resulting number are what you'll want to enter in order to unlock your phone.
Now, let's move on to the slightly more involved path, the MEID...
Really, the only reason that I consider this to be harder than the previous path is because it requires a tool that isn't available on most computers by default. Basically, you'll need to find a hash calculator, specifically one that's capable of working with the SHA-1 algorithm. You don't really need to understand what the SHA-1 algorithm is in order to unlock your phone, but - in case you wanted to know, anyway - I suppose that it'd best be described as a method of making pieces of code more secure. SHA-1 and other similar algorithms simply make changes to code in order to make said code more secure.
Anyway, I'd recommend HashCalc, as it's free and easy-to-use. Once you've downloaded and installed HashCalc, launch it. Change the Data Format option to Hex String, then enter your fourteen-character MEID. Be sure to check the SHA1 checkbox, then click on Calculate. See that long code that appeared to the right of the SHA1 checkbox? Write down the last six characters of it, as they'll be vital in determining your lock code.
Now, this next part will look more than a little familiar. Basically, you'll want to have a scientific calculator for this, just as we did for the first path. Again, in Windows, you can simply launch Calculator and choose View > Scientific from the menu bar.
Once you're in scientific mode, click on the Hex radio button. There's a problem, though: We don't have an eight-character code to put in as we did before, and we need an eight-character code in order to figure out our lock code. Well, thankfully, the first two characters in the eight-character code are always going to be 80. As such, your eight-character code will be the number 80, followed by the six characters that you wrote down after using HashCalc. Now that you have an eight-character code, input that code into your calculator.
Now, click on the Dec radio button. As before, the last four digits of the resulting number is your lock code.
Dec 23, 2009 | Samsung Glyde SCH-u940 Cellular Phone
I cant find the ESN/DEC/HEX number on my LG Voyager, and i am trying to switch to the voyager from an LG ENV, what do i do about the ESN #?
I had the same problem initially for the longest time, but I finally found the MEID number...I don't believe the Voyager has an ESN; I think it only has a MEID number. I also have the Voyager, and I am trying to switch from the phone I'm currently using to my Voyager (my other one broke.) But the MEID number is on the inside of the phone, where you place the battery/back cover. It should be on the sticker that says "MODEL NO" on top. And right below where it says "MADE IN KOREA," it should read "H/W REV : 1. 0" unless your number is different. Right below that it should read "MEID : ," with the 14 digit number; I hope this helped!
Jun 23, 2009 | LG VOYAGER VX10000 Cellular Phone
WHERE IS THE SERIAL NUMBER ID FOR THE LG RUMOUR
take the battery out...it's on the back. (I think)
Mar 18, 2009 | LG RUMOR Cellular Phone
Cell Phones Logo
2,932 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
