Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Does not work flashes error
By Doggy1 on Mar 25, 2008
does not work flashes error code f02
Same Problem
May 16, 2009
-   We have the same problem on our Whirlpool washer duet, front load. It was clogged, got most of the clog out, but we are concerned that the pump is not working correctly. How do we know if the pump has failed? Is it worth a service call and a new pump, or would it cost less to get a new washer. We have had this washer for only 4 years. -   merlin497
Jun 20, 2008
-   Yes F02 error. Definitely some crud in the exterior drain hose. I poured water into the pipe and it seems to drain fine. I have now proceeded with removing the back panel and looking at the dark water remaining in the interior hose. Obviously there is a pump failure, whether this is to do with the pump itself or that there is so much sediment (crud) obstructing the flow is yet to be determined. 3 years ago I had a suds error and ventured into the back of the machine and pulled out a baby sock from the ball in the black hose beneath the wash basin. Put it back togehter and it's worked fine since. My only problem now is if it's the pump itself how the heck do I get to it. And is there electrical stuff-to-do with installing a new one?-   cheery4u
May 25, 2008
-   fronnt load washer f-11-   Guest
May 02, 2008
-   I HAVE THE SAME PROBLEM AND I HAVE A WHIRLPOOL-   sheafive
Best Solution
posted on Mar 25, 2008
Very Helpful)
jsrock516
Rank: Guru  Washers & Dryers  Expert
Rating: 96%, 6839 votes
If this is a Kenmore or Whirlpool model, an "F02" error code indicates a "Long Drain" problem. This means you need to inspect your drain line and or pump to ensure there is nothing obstructing the drain. Can you please post back to confirm correct Manufacturer and Model number?
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
elite oasis is that a quaitly machine
Answer
two flashing lights on machine will not finish wash nosie from machine when it does it
Answer
water drains from the washer but backs up and spills out from the drain pipe in the wall. we just... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Washing Machines:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
