Question about Dishwashers
I have a conia cdw0305s dishwasher.when we put it on wash cycle and put the powder in the door ,after the full cycle the powder is still in the door.the little flap is not opening.
  • Anonymous Apr 01, 2014
    as above
  • Dishwashers Master
  • 713 Answers
Sounds like the dispensor is faulty or the control board is faulty.do u have an electrical test meter to test 4 the fault? please reply if u need more help. if you are in australia conia have gone bust but if u reply i can give u the name of a place that might have a dispensor, if that is the problem.
Posted on May 04, 2010
Conia Dishwasher CDW0305S
go online and type in the model with as much info as possible. Then go to their website and look for more info.
Mar 04, 2015 | Dishwashers
Smell of 'dirty'water when door open. Spins and empties well. no sign of leakage of water. Have used washing machine cleaner but no difference.
Some washing machine guys call this a "Bug" in the machine. Usually caused by a build up of bacteria from the baterial washing powder you use. The easy way to fix this is to use an anti biological cleaner.... Which is what dishwasher tablets are.
Take 3 dishwasher tablets, throw them in the drum, put the machine on the hottest wash you can select and let it run the full cycle with no clothing in the machine. This will probably fix your problem.
Jun 21, 2011 | Washing Machines
CONIA DISHWASHER CDW1211 -Thelittle door that
i find it hard to get parts for these because the are imported from china.it may be better to replace the dishwasher
Jun 08, 2010 | Dishwashers
My whirlpool dishwasher soap dispenser is apparently not opening during cleaning. I find dirty dishes and clumps of soap in the hopper. Whirlpool quiet partner II
I bet your clumps of soap began with the beginning of the use of a different DW detergent powder.
Try this (trust me) Go buy a box of brand name Dishwasher powder (e.g. Electrosol or Cascade) Use it for two loads of dishes and report your results back here. OK?
Apr 17, 2009 | Dishwashers
Where can I find a mnaual that can tell me how to de-lime a Hobart CRS66A Dishwasher?
I doubt that the user manual covers de-liming the Hobart Dishwasher.   If I owned this (fine, expensive) dishwasher, this is what I would do.
1.) Discard any generic, ultra-cheap detergent.  Stop using gels or tablets and only use powders.  Buy a box of brand name powder (like Electrosol or Cascade)  You will be amazed how much difference that will make because the newest generics have mineral bulk added that build up faster then hard water does on both the stainless steel enclosure plus the silverware and even plates.  White patches.  I LOVE generic products and saving money, but low end dishwasher powder is one place I no longer choose a generic product.
2.) Add two cups of white vinegar to the empty dishwasher and leave it there until the morning.  Run a quick cycle with no detergent added.  The vinegar will be pumped out immediately after you begin this quick cycle.
3.) As soon as the dishwasher fills with water during that quick cycle and begins a wash cycle, add two cups of white vinegar and close the door and allow to run the full wash cycle.
4.) When the dishwasher finishes the drain cycle and begins to fill again, open the dishwasher and check the enclosure for remaining "lime" deposits.  If they remain, keep adding 2 cups white vinegar each time the dishwasher refills and begins to wash/rinse again.
You should be delighted with the results. Long term, you should consider adding a whole house water softener and then reduce the amount of dishwasher (and laundry) detergent by one half.  Amazing increase in quality of life by adding a water softener.  You will be delighted.
Please post back with you results, OK?  Good Luck!
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Soap dispensor door opens, but powder soap mostly stays in the cup
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Oct 15, 2008 | Maytag PDB3600A Built-in Dishwasher
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Dishwashers Logo
391 people viewed this question
Top Dishwashers Experts
