Question about Reliable 2000U-33 Mechanical Sewing Machine
Bobbin thread not getting picked up on Reliable 2000u-33. Will not sew any stitches
    Genius:
  • 1,116 Answers
Check the manual to be sure the needle is installed correctly.
There is a groove along the shaft on the front on the needle that guides the thread through the eye of the needle.
If the needle is threaded from the wrong side, no stitches will form.
Once that is resolved, open the bobbin area and watch to see if the needle thread is connecting with the bobbin thread.
If not, the machine needs to have the timing adjusted.
You can find a guide for this at the sewusa website under repair.
However, this is best done by someone experienced with sewing machine repair.
Posted on May 01, 2010
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 10, 2016 | Sewing Machines
Machine wont sew. Misses stitches
check for problems in the bobbin winding, ( in the wrong way so that the thread is not coming out correctly)
top thread tension too tight or too loose
vary the thread tension to see when it improves on a waste test sew
Aug 21, 2016 | Sewing Machines
My Bernette 715 isn't picking up the bobbin thread and is getting jammed. Any ideas what's wrong?
First thing to always try: Install a brand new needle. A dull, worn, or bent needle will cause great frustration. It is also the least expensive resolution to most problems.
Second: Remove all the threads. RAISE the presser foot. Rethread from the beginning making sure it is threaded correctly.
Pull up the bobbin thread before beginning to stitch and hold the thread tails in the left hand while slowly taking the first few stitches:
How and Why to Bring up the Bobbin Thread
If still having issues with not pulling up the bobbin thread, the needle/hook may be out of time.
Sewing machine won pick up bobbin thread hook timing fix
Feb 06, 2016 | Sewing Machines
I can't get the machine to pick up the bobbin thread..How can I fix this problem?
Have you tried installing a brand new needle? The old one may be bent.
Remove all the thread and rethread from the beginning.
Jan 07, 2016 | Lil Sew & Sew 12 Stitch Electronic Desktop...
Does any one know anything about a sewing machine model 217-APP no 457. Think it may be a singer, have just found it in late mother-in-laws shed. It won't pick up the bobbin thread but runs ok
not picking up the bobbin thread is an indication of needle / hook timing
thread tension problems appear as a mess of stitches under the cloth
the timing can be checked by having the needle full down and the hook of the bobbin case should be at the needle just above the eye of the needle
if it is too early or late then it is not in position to get the thread
May 13, 2015 | Sewing Machines
Machine won't stitch
If by "won't stitch" you mean that the top thread will not pick up the bottom thread, make sure you have the needle threaded properly. If the machine is a top loading bobbin, the thread goes in the needle from front to back. Same if it's a side loading bobbin (bobbin faces you as you sew). If it's a front loading bobbin (bobbin faces left of machine), the thread goes in the needle from left to right.
Oct 12, 2014 | Sewing Machines
Won't pick up bobbin thread
Did you check the tension? Sometimes when doing lettering or other specialty stitches you would lesson the thread tension which affects the bobbin thread behavior; did you remember to increase it again before switching back to plain sewing? (Though I would still expect it to pick up the bobbin thread... if it's not picking up bobbin thread then I wonder how the loops are being left on the back side of the fabric; it's the tension of the bobbin thread that keeps the top thread from just pulling through. I'm adding this because maybe that's a clue?)
If you need further help, reach me via phone at https://www.6ya.com/expert/cynthia_b7d259f615af7086
Sep 19, 2017 | Sewing Machines
John Lewis mini sewing machine
This was really helpful for me fixing my daughter a John Lewis (janome) mini sewing machine, and now can get the bobbin thread up again, however, when you sew, the thread is not staying in stitches, just coming off the material completely. I tried forcing the gears on one more time but then it didn't pick up the bobbin thread again so went back to the other gear position. Any ideas of what to try and get it stitching again? Thanks
Apr 02, 2013 | Janome Mini Compact
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
Reliable 2000U-33 Mechanical Sewing Machine Logo
121 people viewed this question
Top Reliable Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Reliable Sewing Machine Expert? Answer questions, earn points and help others
