Question about Hifonics BXi 2006D Mono Block Amplifier Car Audio Amplifier
When i connect the amp to power it pops.The protection light comes on. The speakers and RCA are disconnected. Do you think the is damaged?
  • 1 more comment
  • wulloa483486 May 02, 2010
    the amp sparks and goes into protection.I think their is short in the amp
    I forgot to mention the groung is clean and solid. The amp was working fine I think I pushed too hard
  • uno_1 May 11, 2010
    what do you mean by "pops" the speaker pops or the amp makes a noise all on its own. Are you referring to a spark at the terminal? is your ground clean and solid?
    Scholar:
  • 84 Answers
There is a very good chance its shot but, first check the fuses (on the amp) to make sure they are not blown and make sure it is grounded to clean metal.
Posted on May 02, 2010
Testimonial: "thanks for the quick responce"
  • uno_1 May 02, 2010
    not a problem, sorry i couldn't help...
My Harmon kardon is stuck in protect mode
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check all connections .A thumbs up would be greatly appreciated if this answer is helpful to you. Worth fixing.
Nov 19, 2011 | Harman Kardon Audio Players & Recorders
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
I have an a8000t amp with the protection light on, is the amp broke?
Disconnect the speaker wires then the power and ground completly. Then power up the amp and if the protection light turn on the you have an interanl problem if not then you ohm is problably to low and causing the amp to go into protections.
-david
Nov 09, 2010 | AudioBahn A8000T Car Audio Amplifier
Trying to increase volume on car deck when doing so the amp just shuts off, then amp makes a burning popping sound and smells like something burnt up and 3 sec later amp kicks on and still works, none of...
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Please check impedance on speakers as they coyld be fried as well. A thumbs up would be greatly appreciated if this answer is helpful to you
Oct 03, 2010 | Orion HCCA-D2400 Car Audio Amplifier
The saftey red light keeps coming on
It means that the subwoofer is blown. The red light is called the Protect light. Disconnect the speaker wire from the amp and then turn the amp on and see if the red light goes away. But if as soon as you hook the speaker wires back to the amp and the red light turns on that DEFINATELY means the sub is blown.
Apr 04, 2010 | Cadence TXA 1000D High Power Mono...
Protect
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Send to Rockford Fosgate for repair .A thumbs up would be greatly appreciated if this answer is helpful to you. protect-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
Jan 29, 2010 | Rockford Fosgate Power 1001BD Car Audio...
No sound protection light on.
Either blown subs, or bad amp.. Disconnect the subs, and try turning the amp on, if the amp is still in protect then your amp is bad, if the protect light goes off, then your subs are bad, or possibly wired at to low of an impedance, but I don't think that will trigger the protect on an Audiobahn amp.
Aug 21, 2009 | AudioBahn A2002T Car Audio Amplifier
Protection light
Hello. First, disconnect all of the speakers the amp is driving and the rca inputs while the amp is off. Now power on the remote. If the prot. light still stays on you will need to varify that the voltage across the ground and b+ terminals is a minimum of 12 volts. If this is true than your amp may be damaged due to shorted parts. Otherwise, try to repower the amp while a speaker is connected and if it is O.K. than there may be a problem with the RCA ground in the head unit or the amplifier. We service these amps at Sound Repair 321-690-0808.
Jul 10, 2008 | Kole audio Q1-3000D Car Audio Amplifier
Protection mode?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Double check your connections. .A thumbs up would be greatly appreciated if this answer is helpful to you. protection-mode-shonxoarcym4awy4zl1imx4o-2-0.jpg Lanzar
May 25, 2008 | Lanzar Car Audio & Video
Protection light
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Jan 15, 2008 | Volfenhag ZX-7180 Car Audio Amplifier
Car Audio & Video Logo
78 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
