Question about Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model
The engine start running rough when pto in engaged.
The engine on my craftsman mower runs really well when the mower deck is disengaged. as soon as i engage the mower, the engine starts running really rough. it has electric pto. any ideas?
    Problem Solver:
  • 13 Answers
An air filter can look clean and not be. Remover the air filter and pre filter and try again. If engine smooths out, you need a new air filter.
Posted on May 12, 2010
  • 29 Answers
Are you sure you engine RPM's are high enough? If so adjust you carbs.high speed screw with the throttle in the wide open position.
Posted on May 01, 2010
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
My Craftsman 42" 18.5hp lawn tractor will start fine but when I disengage the brake or engage the blades it cuts off. It was recently left out in the rain while I was working, did something short out? It...
there is a safety switch under the seat. to stay running after the brake is released or deck engaged you have to be sitting on the seat or it will die. if this switch is bad it will die as soon as you release the brake.
Aug 25, 2010 | Craftsman Garden
Mower dosen't run when engaged
The pto switch is also a safety switch, be sure it is disengaged
May 01, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Runs until clutch is disengaged
I would have to say it is some security setting. Most likly it is your seat, if it should turn off when you stand up this is most likly it. So you want to make sure the wires are plugged in better that come out from the bottom of the seat. make sure the connecters are clean when you reatatch them.
Apr 21, 2010 | Craftsman Woodstock Percussion Crcbm ...
Zts has no Power when Blades Engaged
check your blades to make sure that they are not hitting the deck,, this would cause the knocking sound
Aug 19, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Stalls when put in gear or engage mower
your lacking power and probably need to clean your carb or adjust the main idle screw..its on the botton of the float bowl...back it out a half turn...start with a quater..well its running
Jul 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
42 inch Craftsman blades won't engage
model 917258862 mower was given to me. sat outside numerous years. I've managed to get it to start run and drive, but cant get blades to engage. don't know what the wires are for or do that go to some sort of pulley attached to the bottom of motor. can somebody help me pls ?
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Can't get stick to move down to disengage, push with all my power
With the engine off, reach under your deck and pull on the belt. This will force the idler arm back into disengaged position so you can start it. You can probably free the mechanism up with penatrating oil by spraying the pivot point on the idler arm ( the bracket the idler is mounted to that moves back and forth) while alternatly engaging the lever and pulling the belt till it frees up and returns by itself.
May 25, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Runs Great until the blad is engaged
Frozen idler pulley under the tractor frame or frozen or damaged bearings on the deck spindles. With no belt tension on these items they should spin freely. If you have the know-how you can fix the problem yourself (parts are available at sears.com or elsewhere), otherwise you will have to bring it in for repair.
May 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 26 hp 54 in. Deck Deluxe Yard Tractor - CA Model Logo
568 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
