Question about Fisher and Paykel Washing Machines
WATER PUMPING IN SPASMODICLLY AND THEN THE BEEPS COME AND MACHINE TURNS OFF. i HAVE A FISHER PAYKEL MW058U TOP LOADER. SAME THING HAPPENS ON SPIN CYCLE.
  • Fisher and P... Master
  • 713 Answers
There r 3 reasons this happens. 1st the out of balance switch is faulty. 2nd the rotor senor near the motor is faulty. 3rd your control board is faulty. have u got an electrical test meter to test the components? please reply 4 more help. 95% of the time the faulty part is the the out of balance switch.
Posted on May 04, 2010
Fisher and paykel washing machine top loader doesnt spin dry the clothes well. There isnt any water in the machine after the spin cycle but the clothes are heavy wet. What's could cause this?
Machine not spinning. Have you stood next to machine and listened? When all water is drained out (watch the drain hose for water to stop) then you should hear the spin start and hear it building up speed. If it doesn't then you need to post back here with more detail on what you could hear or see happening. i.e. how long after water stopped draining did machine finish and switch off?
Nov 05, 2016 | Fisher and Paykel Washing Machines
I have a fisher and paykel elba washing machine and the drum is not turning during spin and it is tight and cant be moved by hand either. Water is pumping out fine but it is making a clicking sound when...
Does it pump all the water out and then just do small agitations backwards and forward and never engage into the rinse or spin cycle and never come up with a fault code, if this sounds like your problem then can most probably help as I have to encountered the same problem before and now know how to fix this fault.
Sep 28, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel top loader just beeps at the rinse cycle and won't keep going. We had a guy out to repair it. He waited until i wasn't watching, did something, then charged us a lot of money. Now it's...
you did not say if the machine was full of water if so your water pump is probably blocked or failed turn power of to machine lean it back so you can get to the water pump try to spin the pump by rotating the fan on the end of the pump if it releases put washer back in position turn on power advance washer to spin and see if it works let me know how you go
Apr 07, 2011 | Fisher and Paykel Washing Machines
My Model GW712 won't spin or drain Top loader fisher & paykel
hi there the first thing ill tell you is that the washer needs to drain water before it can spin there are only a few factors that prohibit this operation a faulty lid switch secound a blown or blocked water pump being a fisher paykel they are famous for jammed water pumps as they decided when they built the sysyem to turn the water pump upside down this causes a lot of stress on the water pump see if you can lay the hose on the ground and get all the water out i belive the machine will then start to spin dry. in this case it is the water pump and have it replaced its a simple operation if you can order the part fromf/p you simply turn the washer on its side depress the white latch next to the pump turn the pump clockwise till ity release from machine disconnect power supply plug and fit new unit as per reverse
best of luck
sonic boom electronics australia
Nov 06, 2010 | Fisher and Paykel Fisher & Paykel Washer
My fisher and paykel WG708 top load washer fills with water. No rotation of the washer occurs. No machanical sound happens. 4 lights stay on and makes beeping noise. Water will drain but no spin happens?
Hi just read your posting.Could you confirm the model number for me,Is it GW708?Now the lights that stay on when the machine is beeping will be in a row of 8 lights.Starting from left to right which ones are lit when the machine beeps,Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I can help you rectify this fault.
Aug 06, 2010 | Fisher and Paykel Washing Machines
Washing machine stopped during spin cycle. now when i turn it on it beeps and has 3 lights on, 2 wash lights and the spin light. model number is GW611 excellence. fisher & paykel top loader
Hi just read your posting.Now on the wash progress line of lights ,there will be 8 in this row.Starting from the left to the right which lights are lit.Is it the 2nd ,3rd and 7th or the 1st, 4th and 8th ---etc---?Please reply with additional information and I can help you rectify this fault on your machine.Looking forward to your reply
Jul 27, 2010 | Fisher and Paykel Washing Machines
On our Fisher and Paykel, the spin cycle does not
ok guest you can set a fisher and paykel machine to skip one rince cycle so as to save water,
Feb 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel MW058U won't fill
Fault is out of balance switch stuck on i removed and cleaned mine with crc but if still stuck on may need replacing hope this solves your problem
Jun 18, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
167 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
