Question about Nokia 6600
6600 ringtone My 6600 is set to ringing mode but when someone calls or i listen ringtones it just vibrates
Please help problem with ringing tone...
Posted on Oct 28, 2008
Go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Posted on Mar 27, 2008
My iPhone 5c won't ring
Does the phone plays music without any problem? If you play music to hear it on the loud speaker, and there is no sound, then you probably have a hardware failure, (bad speaker). But if you get to listen to the music, then try this next steps to see if it can be fix.
  • From the iPhone's home screen, tap the Settings app.
  • In Settings, tap Sounds in the third group of options.
  • In Sounds, swipe down to the Sounds and Vibration Patterns section. In that section, look forRingtone. That displays what you have set as your current iPhone ringtone. Tap it to change that.
  • This menu shows you the list of all the ringtones available on your iPhone.
    To get new ringtones, tap the Store button in the top right corner. This will take you to the ringtone section of the iTunes Store where you can stock up on new ringtones.
  • If you choose not to buy new ringtones, but instead use the ones loaded on your phone, the first set of options in the Ringtones section are ones that you bought from the iTunes Store or created using another app and have synced to your iPhone. The ones below the divider came pre-installed on the iPhone.
    Alert Tones, farther down the screen, aren't ringtones exactly. They're alert sounds normally used for alarms and other notifications, but they can be used as ringtones, too.
  • When you tap on a ringtone, it will play so you can preview it and decide if it's what you want. When you've chosen the ringtone you want to use as your default, make sure it has the checkmark next to it. Then tap the Sounds button in the top left corner or click the Home button to go back to the home screen. Your choice is saved automatically.
  • Now, whenever a call comes in, the ringtone you just selected will play (unless you've assigned individual ringtones to callers, that is. If you have, those ringtones take precedence). Just remember to listen for that sound, and not a ringing phone, so you don't miss any calls.
  • Mar 13, 2014 | Cell Phones
    How do you adjust the volume on the Samsung T255 StraightTalk phone?
    Sound Settings
    You can customize various sound settings.
    Incoming call
    Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
    This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
    This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
    • Use the Right or Left key to increase or decrease the volume.
    Alert type
    This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
    The following options are available:
    - Melody: the phone rings using the ring melody selected in the Ringtone menu.
    - Vibration: the phone vibrates but does not ring.
    - Melody and vibration: the phone rings and vibrates simultaneously.
    - Vibration then melody: the phone vibrates three times and then starts ringing.
    - Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
    Message tone
    This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
    • Use the Up or Down Navigation keys to make your selections.
    Keypad tone
    This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
    phone sounds when you press a key.
    Jan 25, 2011 | Samsung T239 Cell Phone
    My mobile (model: nokia 1650) restarts when I try to set the ringtone. My phone is now in silent mode and does not ring or vibrate for any incoming calls. Could you please provide a solution for the same....
    you want to goto settings in your mobile phone and select restore factory setting, in that type the security code 12345 and press ok .then the problem will be solved
    Dec 30, 2010 | Nokia 1650 Cell Phone
    My Slice phone no longer rings out loud or vibrates when a call comes in. How do I restore those settings?
    Check out this link for a PDF manual for your phone. Just copy and paste into your browser.
    I got this info off of page 60 from your manual.
    Control the volume for Ringtone, Speakerphone, Headset, and Advanced settings.
    Set ringtone volume and incoming call alert options:
    1. Press [Menu], then press "Settings".
    Press "Sounds", then press "Volume".
    2. Press "Ringtone".
    3. Press / to adjust the volume level. Press to select Vibrate when High is the volume level.
    The volume settings available are:
    • Silence all: All sounds are off.
    • Vibrate : Phone will vibrate to alert you of incoming call or message.
    • Off: Only the ringtone is muted.
    • Ringtone mode: Low, Medium, High.
    Tip • You can adjust the ringtone volume with the side keys.
    Hope this helps. Let me know if I can help you with anything else.
    Oct 05, 2009 | UTStarcom PCS1400 Cellular Phone
    Ring tone vs vibrate
    There is no option to turn off the ringtone. You're not doing anything wrong. The only way to turn off the ringtone is to use the volume button to turn the sound off or to vibrate, or using the hot key (#) to go to "Vibrate Only Activated". I hope this explains what you wanted to know.
    Aug 19, 2008 | Samsung SCH-u340 Cellular Phone
    Ring vs vibrate
    This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
    You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
    If this helps you, please leave me a good rating.
    Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
    6600 Cellular Phone
    Just copy the ringtone in phone memory which you want to set. It will give you option to set it as ringtone.
    Jan 17, 2008 | Nokia 6600
    Ringing Tone
    Ringtone/Ringtone "PLAY" function not working
    crazzyyy problem...
    i suggest take it back wherever you got it!
    Nov 07, 2007 | Motorola Mobility MoroKRZR K1m Cellular...
    hi, before applying tone, play it & listen, if it plays sound. Resent ur mobiles master setting & apply now. bye
    Oct 01, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
    Nokia 6600 Logo
    388 people viewed this question
    Top Nokia Cell Phones Experts
    Computer Repairing
    Computer Repairing
