Question about Jabra BT350 Bluetooth Headset Headset
Need to put bluetooth in pairing mode and lost instructions
  • 185 Answers
How to connect a bluetooth to a cellphone
1. go to the menu on you cellphone and find connections-bluetooth
2. click options
3 be ready to click search for device (don't click it yet)
4. press the on button and your earpiece and hold till you get a solid bluelight.
5. when you get the solid blue light on earpiece click search for device
6. when it finds your device select it and click on it
7. it will then ask for a code or if you want to bond or pair the devices click yes and type 0000
8. it will ask you to confirm click connect
you should be able to connect.
if it works for you don't forget to rate me
thx
Posted on May 01, 2010
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
Hi I have an emerson em227 bluetooth and haver lost the direction. I need the instruction to start the paring process
You must put you headset in pairing mode, prior to trying to pair it with your phone. In order to do it, starting with it turned off, press and hold the power button for some 10 seconds, until the indicator light is alternately flashing in red and blue. It is in pairing mode now. Then, bring your phone close to it, and make its bluetooth application search for new devices. After a little while, your headset should appear on your phone' screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode (blue light flashing every few seconds).
By the way, If its user guide happens to be missing, or, rather, you need further informations on how to pair it with your phone, feel free to download it from this location.
Regards, Carlos
Jan 13, 2011 | Emerson EM227 Bluetooth Headset
How do i put it in pairing mode. lost my instructions and changing phones.
the phone does not go into pairing mode the device you are connecting does ( ie Bluetooth headset ) you use the phone to search for the device
Aug 04, 2010 | Cell Phones
Ive lost my instructions for my headset device i need to know how to turn my phone to headset pairing mode
Hello my friend,do these steps
Pairing with another Bluetooth device
By pairing your KU990 and another device,
you can set up a passcode protected
connection. This means your pairing is
more secure.
1 Check your Bluetooth is On and Visible.
You can change your visibility in the
Settings menu.
2 Touch Paired Devices then New.
3 Your KU990 will search for devices.
When the search is completed Refresh
and Add will appear on screen.
4 Choose the device you want to pair with
and enter the passcode then touch OK.
5 Your phone will then connect to the other
device, on which you should enter the
same passcode.
6 You passcode protected Bluetooth
connection is now ready.
Using a Bluetooth headset
2 Follow the instructions that came with your
headset to place your headset in pairing
mode and pair your devices.
3 Touch Yes to Connect now. Your KU990
will automatically switch to Headset profile.
If you have any questions you can try reading the manual here
http://www.in.lge.com/Product/Manual/KU990.pdf
Jan 11, 2010 | LG KU990 Viewty
Need instructions on how to pair bluetooth motorola H710 with blackberry curve
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Dec 25, 2009 | Motorola Mobility H710 Bluetooth Headset
Lost instruction manuil for my mad catz bluetooth wireless headset
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
You can obtain a copy of your user manual by locating the FCCID on the label directly on the device, then then going to the FCC Website - https://fjallfoss.fcc.gov/oetcf/eas/reports/GenericSearch.cfm
Be sure to put the first three characters in the first box and the rest (including hyphens) in the second box.
Sep 04, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
Need to setup H300 bluetooth to my LG VU phone! How do I do this?
The quick answer is that you can put it into pairing mode, and your phone should recognize it. To put into pairing mode, push and hold the large power/answer button for at least 6 seconds. The light will start flashing, indicating that it is in pairing mode. Go into the Bluetooth menu on your phone and make sure Bluetooth is turned on, that your phone is visible, and that you can search for new headset devices. Make sure the headset is still flashing. When you discover the headset in the phone, it may prompt you for the code. I believe the pairing code is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
Jan 08, 2009 | Motorola Mobility H300 Wireless Headset
Bluetooth
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
Nov 07, 2007 | Motorola Mobility H500 Wireless Headset
How do i connect my bletooth h350 to my phone
Hi, follow the steps to get your product paired. Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset With the headset power off, press and hold the Call button for 6 to 10 seconds until the blue indicator light turns on and remains steadily lit. (The light will flash while you hold the Call button.) If the indicator light is flashing or does not remain steadily lit, turn off the headset and repeat step above. Step B - SET THE PHONE TO LOOK FOR YOUR HEADSET Select (Menu) > Settings > Connection > Bluetooth Link > Handsfree > Look for Devices. The phone lists all Bluetooth devices it finds. Select Motorola H350. Press OK or Yes to pair (link) the handsfree device. Enter the passkey 0000 and press OK. Note: Passkey cannot be changed from 0000. When your headset is successfully paired with your phone, the blue indicator light changes from steadily lit to flashing. additional help http://www.motorola.com/mdirect/manuals/QG-H300_9495A08A.pdf all the best sreejith 2 Step A - PUT HEADSET IN PAIRING MODE Note: To turn off headset
Jul 16, 2007 | Motorola Mobility H350 Wireless Headset
Jabra BT350 Bluetooth Headset Headset Logo
501 people viewed this question
Top Jabra Radio Communications Experts
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
