Question about Mitsubishi WT-46805 46" Rear Projection Television
Push power button and it clicks once then green light goes out and then clicks again and then nothing happens
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Do the self check the model indicated has:
When power light goes out on the front of the set press and hold both the Menu and Input (device) buttons for at least five seconds and then release both buttons.
Watch the power light closely as it will blink a two digit error code: 2 blinks and a pause followed by 2 blinks is the most common one.
It will repeat the code about 5 times and then to get it to do it again you would have to unplug the set and attempt to turn it on again etc.
Let me know what code you find and I will tell you what it means and what kind of trouble you have.
SD TECH
Posted on May 01, 2010
  • Greg Combs Apr 30, 2011
    I am having similar symptoms with this model. The error code I get is one blink, pause, two blinks. What does this suggest? While plugged in with no power indication on the front I can feel heat coming out of the back and hear a "sizzling" sound toward the side where the flyback transformer sits. A brief visual inspection of components I can see without removing the circuit boards does not reveal any parts that look overheated. Thanks for your assistance!
  • mr_stinky_1 Aug 27, 2011
    So we're getting the two blinks- pause-two blinks so where do we go from here to fix the problem (the tv not powering on)
My computer says it is charging but as soon as i hit the power button it stops charging and does nothing even happens
Have you tried running the computer with just the AC plugged in and not with the battery? If not try that. It could be the battery is going out. I had a similar issue once. If that doesn't work it might be the power supply / powercord or it could be the motherboard.
Jan 17, 2013 | IBM ThinkPad T30 2366 Notebook
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
I have an lg plasmas model # 42pc5d-uc the tv is not turning on. When I push the power button the red light flashes a few times I hear a click & nothing happens it goes back to a solid red light...
All put the name in with the model. Its a LG .Your power supply is down. This could be capitator or transitor bad if the caps are swelled up replace them with the same value .
Mar 01, 2011 | Televison & Video
Canon Pixma MP140 freezes, only alarm lamp is on, no code error
  • Turn off the canon printer
  • Hold the Resume Button (red circle in the triangle), add a printer (click “Power”) an indicator light green.
  • Hold the Power Button, release the Resume Button.
  • Not releasing the Power Button, double click “Resume” and release Both Buttons.
  • Click “Resume” for Four times
  • Once you click “Power”, to confirm the selected action (reset counter absorber). To disable the printer “Power” button to click again.
  • Jan 01, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    Power on/off
    that is a common problem with this rca's check the convergence board for a short circuit
    more likely is a transistor or an convergence ic
    caypianan@yahoo.com
    Jul 18, 2008 | RCA HD52W58 52" TV
    My big screen tv went off and reset it but you push the button and the power comes on and goes right back off
    when we push power button the green light flashes as if thinking about turning on and nothing happens, any way to fix this?
    Feb 18, 2008 | Televison & Video
    Push Power button, green light goes on for a few seconds then nothing....
    I would suggest taking a look at the power module if that can be replaced. The Fuse blowing may have only been the beginning of the problem. Any recent issues with under or over voltage in your home?
    Jan 20, 2007 | Mitsubishi VS-60601 60" Rear Projection...
    Mitsubishi WT-46805 46" Rear Projection Television Logo
    222 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
