My tablet is not pluging in
Hey i have an old verson of tosibia tablt and it wont start up the charger and the power butten or blinking i pluged it in and it wont work. my charger works on my sisters tablet even though hers is a different verson
    Sergeant:
    Champion:
  • 304 Answers
Toshiba computers have a label on the bottom that displays the exact voltage and minimum amperage required to power the computer ("DC15V 3.0A", for example, which means 15 volts DC (direct current), at 3.0 amps. Each Toshiba AC adapter has a label indicating its output voltage and amperage capacity (for example, "DC15V 3.0A"). Important considerations for using AC adapters with portable computers:
The connectors must be compatible -- they must mate together correctly.
The voltage level must match exactly (a computer designed to run from 15 volts can be powered only by an adapter rated to produce 15 volts). If the AC adapter's voltage is higher than the computer's requirement, the computer and the battery may be damaged, If the AC adapter's voltage is lower, the computer may not operate correctly, or not operate at all.
The AC adapter must supply at least enough amperage (current) to meet the computer's amperage requirement. Otherwise, the computer may not run properly, the battery may not charge correctly, or may charge very slowly.
The quality of the power (ripple, noise and other factors) provided by the AC adapter must be very high. AC adapters from other manufacturers may supply sufficient amperage at the correct voltage level but the quality of the power may be poor, which can cause the computer to operate erratically, and could even cause damage to the computer. Whenever possible, use the correct Toshiba AC adapter for your computer.
The computer's power light may blink to indicate that there's a problem with the power from the AC adapter.
Posted on Mar 25, 2008
  • Elizabeth Krijt
    Elizabeth Krijt Mar 25, 2008
    IF YOU GOT A NEW BATTERY AND YOU STILL GOT THAT PROBLEM.....
    This is a normal
    consequence of the battery being in need of a fresh charge. For best
    results, allow the computer to charge the battery for about 24 hours
    before turning on the computer.
    Batteries discharge whenever they
    are not being charged. Even when the computer is turned off, it draws
    some energy from the battery. A battery that has been removed from the
    computer will slowly self-discharge, limiting its "shelf life".
    eNJOY!
Hey. sumsung ce0168 device wont power up. pluged in and reset switch doing nothing, any ideas?
The battery may be an open circuit, this means even when the tablet is connected to AC power the device will not operate.
Oct 07, 2016 | Samsung Tablets & eReaders
When tv is unpluged and pluged back in it wont power on and no lights blinck
Sure the plug is getting power from wall outlet? If power is there you might want to check out the power supply board first for issues.
Oct 13, 2015 | Televison & Video
What else can i do to try to fix my nephews tablet? It wont turn on at all. Ive charged it and still aint working! Getting fustrating!
Try pluging usb cord into a computor from tablet to see if it will connect. link them together?
Mar 18, 2015 | Tablets & eReaders
What do i do if my tablet wont charge
Lol Deer Hunter 2014, Oh my!
Anyways, try another power cord and also try it in another power outlet
If you leave it plugged in for a few hours, does the tablet itself feel hot or warm? Does the plug itself feel hot or warm?
You may need to find someone else who uses the same type of charger or bring your tablet to a pc repair store to see if they have a charger to try it out.
Jul 24, 2014 | Ematic 7" Touch Screen Tablet
Will not turn on
markus could it be that you formatted the internal flash and not the external SD ?
try removing the SD from your tablet and restarting it make sure it's pluged to the charger so we dont have a power issue
Apr 07, 2014 | Coby Kyros 716829701508 Tablet PC
Battery not charging tablet gets hot and wont turn on
The battery is dead and cannot be recharged. Replace the battery.
Mar 26, 2014 | Polaroid S7 7-in. Internet Tablet
I pluged my tablet in to charger it turned off wont turn back on and makes ticking noise hkc 8" capacitive multi touch tablet duel core processor
It may be that it has to be charged longer, before you try using it when plugged in. it has happened with my tablet as well.
Mar 02, 2014 | Tablets & eReaders
Battery stopped working
Hey,
Test your charger, the battery light blinking and the computer not starting up indicates not enough power to start up or not pluged into ac power, check the power adapter or charger. I suspect the battery is fine.
Thanks,
Ekse
Feb 15, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
