Question about Bosch BSA2222UC Compact Plus Bagged Canister Vacuum
Bosch bsa2222uc doesn't turn on at all - non-responsive to any fiddling - cleaned the filter, won't turn on with hose unplugged either.
  • 159 Answers
Check electric cord on the machine it may be broke leave power on shake cord if cut in and out replace cord
Posted on May 10, 2010
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Vacuum roller won't turn and there's no suctions. Red light Doesn't blink
go to http://www.dyson.com/
get the support and download the model, troubleshooting, video for your trouble.
God bless you
Sep 16, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
The brushes won't turn, and cleaning the filter (as suggested in the owner's manual) doesn't help.
Hi ken wright.
Remove the bottom of the head of the vacuum...remove the roller brush assembly.
Clean the assembly...remove the end caps and clear all hair,strings,etc from the end cap and rotating brush head.
After cleaning the brush head and bearings, lube the bearings with a good grade of machine oil such as 3 in 1 oil.
Check your belt condition.
Reassemble and you should be good to go
Please take time to rate me
Sep 05, 2011 | Vacuums
The 70210 is a few months old. It doesn't ****. There is suction going into the canister, but it's not reaching the hose. I've ensured there's no blockage in the hose, blown it clean with...
IF you can use a broom stick to run through the hose to make sure that there is nothing in it, then you need to check the output filters. They get plugged up with fine dust particles and the suction is reduced. The output filters can usually be rinsed out.
Dec 18, 2017 | Hoover UH70210 Bagless Upright Vacuum
Vacuum will no longer turn on. Vacuum bag was
Same problem. I suppose BOSCH dumped these into the market and have chosen to disown them. Support is pitiful and vacuums have also been taken off their website. Too bad, was a nice quiet product for the 2 months it worked. Solution = new, non-BOSCH vacuum.
Oct 04, 2009 | Bosch 12-Amp Formula Canister Vacuum with...
No suction on Bissell Powerforce Bagless. Have thoroughly cleaned
Make sure you unplug before cleaning turn vaccum upside down check roller
for hair and strings wrapped around brush if this does not help clean out cylinder gently knocking dust out or use a duster to stick up inside lightly cleaning and check filter
Sep 30, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bosch BSA2222UC canister vacuum shuts off after 5 minutes
You have a plugged vacuum indicator port. There will be a tiny hole somewhere near the hose inlet. Just clean it with a dry toothbrush. This will allow the vacuum pressure to equalize on either side of the shut off switch.
Jan 03, 2009 | Bosch BSA2222UC Compact Plus Bagged...
Bosch vacuum Motor turns off after a few minutes
It sounds like you have a motor protection fuse that resets after an overheat/cooling cycle.These work the same as a circuit breaker in your house with the difference being they can reset themselves.The Bosch will also shut down if there is insufficient airflow and I would check your filters first.1) Pull the filter and let the machine run.Do not pick up debris when you operate without a filter-it will be drawn straight into the motor.If it runs fine without shutting down, all you need to do is change your filter.If it shuts down again check the external hose for any blockages.Also check the throat from the powerhead for any blockages.If you continue to have the same problem then you will need to replace the fuse because at this point you have eliminated all the other likely problems.Good Luck-Scott
Oct 08, 2008 | Bosch BUC11700UC Cyclone Jet Bagless...
Not picking up
Did you check down by the brush roll? If the hose has suction, then the problem has to be in the nozzle asm. The hose having suction tells you that the main part of the vacuum is working ok.
Mar 17, 2008 | Eureka 7618 Bagged Upright Vacuum
Bosch BSA2222UC Compact Plus Bagged Canister Vacuum Logo
114 people viewed this question
Top Bosch Vacuums Experts
Billy Detlefsen
ray gallant
JoeVacs
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
