Question about LG LHD45EL Dehumidifier
Ice forming on the to
Ther is ice forming on the top of my dehumidifier along the crack between the front face plate and the top housing. It still seems to be drawing water out of the air, but Ihave to shut it off and let the ice melt every now and then. What causes this?
  • LG Master
  • 5,415 Answers
Usually this happens for one of two reasons: 1) there is a problem with the refrigerant and/or compressor (like a little leak of refrigerant)
2) the room that the compressor is in is too cool (below the operating range of the dehumidifier)
If the unit is under warranty, call for service if you know the room is above the minimum operating temp. If it is a problem with the refrigerant, they will probably replace the unit.
I hope this helps.
(we have an LG dehumidifier and had to have it replaced when it was less than a year old - it was icing up in the summer. It still iced up in the winter (at times due to cold in the basement).)
Posted on May 01, 2010
Testimonial: "Thanks. That is what I was afraid of."
HI, OUR DEHUMIDIFIER SWEATS ON THE TOP (FORMS WATER BEADS) AND PARTIALLY FORMS ICE.
>check if the steam creating by the dehumidifier is enough or balance to neutralize the fresh air supply of the dehumidifier by not creating a too much moist or more tha 40% relative humidity so that water beads would not form from the top of the dehumidifier unit or from its supply of fresh air.
Jun 18, 2011 | LG LHD65EBL Dehumidifier
I've got ice forming on top of the humidifier along the joint where the faceplate attaches to the main box.
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
May 24, 2011 | LG LHD45EL Dehumidifier
Ice started forming on top of unit and now it has shut off and won't restart. It hasn't been running efficiently for past few weeks. Can I fix it?
If the surrounding temperature is low enough the condensing elements of a dehumidifier ice up just like the cooling plates in a frig. Either reduce the power or raise the surrounding air temperature.
Jun 14, 2010 | LG LHD65EBL Dehumidifier
Ice forming on top front part of unit
usually, ice build up is caused by low refrigerant levels (a dehumidifier is essentially an air conditioner). depending on the unityou may or may not be able to service it. Some of these systems are sealed at the factory and a pierce valve is needed to add refrigerant to the system.
May 07, 2010 | Goldstar DH504EL Dehumidifier
Bucket not filling - ice forming on lid.
You've developed a sealed system problem.
Apr 07, 2010 | LG LHD45EL Dehumidifier
Running, but no water coming out. Is forming ice
Your machine has a sealed system leak and is low on freon. Read your owners manual and there should be a 5 year sealed system warranty. If so you will need your purchase receipt and call an authorized LG dealer for an exchange.
Oct 09, 2009 | LG LHD45EL Dehumidifier
Icing on front of dehumidifier while it is
You are operating it in an environment where it is too cold.
Oct 04, 2009 | Dehumidifiers
Dehumidifier freezes up
Most dehumidifiers need warmer air to work properly. The temperature in a basement is usually 60 - 65F; too cool for standard models. You could buy a "basement" dehumidifier. They're designed to work at lower temperatures; some as low as 40 F. Costs are about the same as a standard dehumidifier; you just have to find it.
For a cheap fix, try this; it seems to be working for me.
Since the condensate coil (the one icing up) is cold, the air entering it is too cool and the condensate frosts up the coil. Additional condensate freezes to the frost and before you know it, you've got a block of ice. Since the air coming out of the front is very warm take a large piece of cardboard around 6' x 3') and form a V. Placed it in front of the dehumidifier so it channels some of the warm air back to the rear where it warms the moist air up before it hits the cooling fins. It's helped keep the ice down.
If you want something attractive, any screen that redirects some of the air back to the rear will work. Just leave the top open so it doesn't get too hot and the some of the drier air gets out into the room.
Jul 02, 2008 | GE AHG40LJ Dehumidifier
Ice on dehumidifier
A dehumidifier works by cooling the metal pipes on the back of the unit to create condensation (water vapor in the air). This then drips into the collector bucket. If the unit runs too long the cooling tubes can get too cold and freeze the condesing water vapor. Unplug the dehumidifier and let the ice melt, when u turn it back on, turn it down, it may be up too high. If you find this solution helpful please rate it.
Thanks - Tech101
May 20, 2008 | LG DH404E Dehumidifier
LG LHD45EL Dehumidifier Logo
600 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
