Question about Olevia LT37HVS 37 in. LCD HDTV
How can we view cable TV when the TV doesn't have a tuner?
The TV will work with a cable TV box, but we want to be able to use it without a box. Can we buy a tuner that will hook to the TV?
  • Olevia Master
  • 8,457 Answers
Ur tv is a digital tv.Just buy a Digital antena or a roof antena hook it up.Go to SETUP menu go down to CH. SETUP pick AIR,not CABLE and than enter to scan.After ur tv done scanning,u will get all the free air DTV channels.
Posted on May 01, 2010
There is no cable outlet on the tv
If there is no RF (coaxial cable) input, you need a set-top box (tuner or cable box) to watch TV programs. The TV doesn't have a tuner built in and was sold as a monitor.
Which model of TV do you have? What type of cable are you trying to watch? With the additional information, I may be able to suggest an set-top box for you.
I wish that I had better news for you.
Apr 29, 2012 | Televison & Video
Do these TVs have tuners that allow then to pick up and view digital broadcast stations without being hooked to a cabelo or satelite system?
The Emerson LD195EM8 has both an NTSC (analog) and an ATSC (digital) tuner with an RF (coax) connector. So you will be able to watch current OTA TV without a set top box (cable/satellite/converter).
I hope this helps.
(assuming no damage to the tuners or the input jack)
Jun 06, 2011 | Emerson LD195EM8 19 in. LCD TV
When I hook up the cable to the RCA truflat tv the screen stays blue. I had it working with a cable box, do you know why it's not working with just the cable?
Your cable system is probably digital, and the tuner in this TV isn't compatible with the system. The cable box output was a regular TV channel 3 or 4 signal the TV could tune in. Without the box, though, your TV's tuner sees nothing. You'll need to stick with the box.
Jan 12, 2011 | RCA TruFlat 27F520T 27" TV
If i buy a full hd tv,instead of hd ready,can i view HD PROGAMS from outdoor arial without anymore setup. thank you A R SHEARING.
You do not want to buy HD ready (ready means it will accept HD sources), Ful HD TV will have ATSC digital tuner for off the air signal, you will want it to have QAM tuner also so if you decide to get cable, you can get unencryped HD programs without using the cable box (that is what I am using with my Entended BASIC Comcast cable without using/renting their box, Comcast gives three free boxes, then you have to rent the rest if you have more than 3 TVs at about $7 a month).
Nov 19, 2009 | Televison & Video
I have an Akia tv with no tuner.How can I get this to work without getting a cable box?
If your TV doesn't have a tuner then the only way you can tune channels is by using an external tuner like a cable box.
Sep 14, 2009 | Televison & Video
I have a 47'' phillips lcd flat screen,will my tuner work without using cable box(timewarner) and still pickup all the channels
If the TV tuner has digital connection with HDMI, or th white red and yellow connectors for RCA cable, it will work with the new TV.
If the tuner has only coax round antenna-like connector, then it will not work with TV tuner.
Many new TV also do not have scart cable connector, but adapters Scart to RCA are available.
May 05, 2009 | Philips Televison & Video
On my cyberhome 1600 dvr want to view tuner of dvr on tv screen
Take your TV for a check by a good technician. Some IC have short circuited in the accident that occured.
Rate this...
Mar 22, 2009 | Cyberhome DVR 1600 DVD Recorder
How to view TV in a Desktop PC via a USB TV Tuner?
Depending on which kind of tv tuner you are looking (analog basic cable) or HD tuner, the higher end tv tuners will usually handle both basic cable or connecting via satellite or some sort of set top box.
I would look for the ATI TV wonder HD, your going to want a tv tuner that can do hardware encoding on the actual tuner itself, older tuners will rely on your pc to process a lot of the data.
Mar 18, 2009 | Compaq Computers & Internet
Picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Jan 01, 2008 | Panasonic CT-32D31 32" TV
Tuner problem? (hope not!)
check if you put the cable in tuner A OR B CHANGE WITH REMOTE MAY BE NEED GOOD CONETION OR PUT ONE SPLIT T CABLE AND RUN ONE CABLE TO TV IN A AND OTHER B CHECK THIS NOT TRAY SPEAK SPANOL THANK YOU
Sep 27, 2007 | Philips 51PW9303 51" Rear Projection...
Olevia LT37HVS 37 in. LCD HDTV Logo
230 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
