Question about Gaggia Syncrony Espresso Machine
Gaggia Synchrony Digital - the FILL WATER TANK message stays on
The FILL WATER TANK message kept coming on even though the tank was full. It would go off sometimes when I picked up the tank. I got it to run through a descale cycle and two rinse cycles but now the FILL WATER TANK message is on all the time no matter what I do. I am able to get to the menu but I can't run rinse or any other command that uses water.
  • kevin_colyer May 01, 2010
    I took out the float and cleaned it. This seemed to do the trick. I didn't think it was sticking but it must have been.
    How does it work anyway? Where is the sensor that the magnet interacts with?
    Thank you both. That was awesome, fast, and fixed my issue immediately.
  • 10,515 Answers
Is this a New Machine?
If yes, you need to Contact the Manufacturer for Weight Sensor.There are many Reports that People are getting this Message due to the Weight Sensor.
If that is an Old Machine, Chances are there, it could be at Fault.Check the float in the water tank,it can stick or leak water and sink to the bottom.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 01, 2010
  • taran_2005
    taran_2005 May 01, 2010
    OK!!
    Also there is a little floating black thing at the back of the container, this
    works as a magnet switch. see if it is there or is stuck and doesn't
    raise with the water level.
    Hope i helped you.
    Thanks
Gaggia syncrony compact digital expresso maker says fill water tank but water tank is full
Check the float in the tank that indicates the water level to the sensor. They often fail to float, solution is to either replace the tank or jam something plastic under the float to lift it to the top of its slot.
Jan 01, 2016 | Gaggia Syncrony Compact Digital Espresso...
Gaggia Titanium SUP027 YDR Syptom: Displays Fill water tank even though the water tank is full and freezes the operation of the coffee machine
Be sure to check the float in your water tank. It looks like this: http://www.cerinicoffee.com/item.asp?PID=1318
If the float is not floating then you need to replace it.
Jun 05, 2011 | Gaggia Titanium Espresso Machine
Fill water tank message will not go off screen even though tank is full
Your magnet might have come out the the tank. You might have to get a new tank.
Sep 08, 2010 | Starbucks Saeco Italia Digital Barista...
Who do you decalcify your synchrony espresso
I assume yours is not the digital, here are some instructions for properly descaling your machine.
1. To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Once it is dissolved, place the tank back on the machine, and then turn the machine on.
2. If you just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. Longer is better. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
3. Repeat step #2 for your machine. Do this until you have consumed the entire water tank of solution (approximately four to five cycles). (I do it at night before I go to bed and let the last cycle set in the boiler till morning.)
4. Remove water tank and rinse it with fresh water.
5. Refill water tank with fresh water and place it back on the machine.
Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is no need to let it set.
Remember, it is better to descale more often than not enough.
Nov 20, 2009 | Gaggia Synchrony 90101 Espresso Machine
Fill water tank message appear even when tank is full
Jul 17, 2009 | Gaggia Titanium Espresso Machine
Low water light stays on
If water light and heating lights go on and off, Try this: Fill water, turn water nozzle on, let water flow out. Water light should go off. Shut off water.
If coffee lights are solid, turn off the machine, let it cool off and try the above again.
Jul 07, 2009 | Gaggia Syncrony Compact Coffee...
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Fill Water Tank But Water Tank is Full
hello in the water tank they is a float it was probably out of water for a while and the float is stuck take the container in our hand and tap it gently by doing that the float gonna get loose move the container you gonna ear the float move put it back fill with water enjoy cheers
Jan 14, 2008 | Gaggia Titanium Espresso Machine
Gaggia Syncrony Espresso Machine Logo
224 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
