Question about Sony KP-53S70 53" Rear Projection Television
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
  • Sony Master
  • 8,457 Answers
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
Posted on May 01, 2010
Standby/timer light stays on red. no picture or sound on tv.
this is a simple capacitor fix at your local tv guy..should be 100 to $150 max
Apr 09, 2014 | Sony KP-48S75 48" Rear Projection...
Standby/timer flashes and screen goes black
How many times do this standby light flashes at one time switch ON? Count it. These flashes are fault indications. From the number of flashes, you can get an idea about which section circuit inside it is faulty. After confirming it, If you wish to get more details of these blinking codes, check this link.
Mar 02, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Red standby button lit but black screen and no sound?
Google model # look for service manual. Depending on the number of blinks, it will help you isolate problem.
Apr 21, 2012 | Sony KP-53V85 53" Rear Projection...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
Screen will begin turning blue, then go black and standby timer light blinks 8x in sequence. I can repower and screen will come back on temporarily. Tv may work for days then suddenly start doing again....
hello ,Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
shaun
Nov 10, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony Rear Projection TV - KP-46WT500 Screen went blank
When Sony TV gets problem it goes to standby as protection mode and LED start flashing.
Do you see standby light blinking?
There would be 3 seconds interval between blinks so count from pause to pause and let me know.
Thanks.
Sep 20, 2009 | Sony KP-46WT500 46" Rear Projection...
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Will not turn on
how many times does the light blink? There is a diagnostic set-up built into these Sony TV sets.
Apr 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-53S70 53" Rear Projection Television Logo
180 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
