Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Zanussi dishwasher not heating up whole programme is running on cold
Were do I find the heating element in my dishwasher so that I can change it
  • 76 Answers
Bosch dishwashers run the cycle through the heating element, you may get a 2H displayed. when you wee that it means the heating element is bad, or the board is bad, i will tell you in my 15 years of repair its almost always the board,. if you know someone who is solder literate, the you can remove the board and resolder the connection. you need to remove the screws on the inside top of the door to remove the display panel, after doing so you will see the control board(fisrt turn off the electrical) then remove the wiring harnesses from the control board, the harneses only go in a certain slot so they will be easy to remember where to put back into.open the case of the board, look on the back and you will see where the bad solder joint id...clean, resolder, reinstall......good luck. please check this first before trying to change the element. you have to take the dishwasher out and flip it over to change the element
Posted on Jan 08, 2009
My zanussi dishwasher, zdf 301 isn't heating water so only running cold washes.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 03, 2011 | Dishwashers
Zanussi 6015 dishwasher washes in cold water
the dishwasher might accept cold water but must heat the water up during the cycle. If it does not then check the heater circuit......element...thermos NTC, with a meter for electrical continuity....some dishwashers stop mid cycle if the re is no heat but some go right through on cold depending on the make.. good luck
Mar 01, 2011 | Dishwashers
Only cold water on all programmes
heatman101
Oct 17, 2010 | Dishwashers
No water heating
More likely to be a faulty heater, but to be certain, you will need to test the heater with a meter.
Hope this helps.
Jan 22, 2010 | Zanussi Washing Machines
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
Dishwasher not heating Zanussi
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
lmnbv
Mar 30, 2009 | Zanussi 23 in. ZDi6053SX Built-in...
Zanussi FLE1416W Front Loader
Most possible reasons that the door switch or timer unit is defective. The dishwasher should heat the water to about 55 C as the heating cycle starts. In these cycle, the dishwasher pauses after has filled with water and wait for the water to reach the temperature. If the water isn't being heated (because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. if you think that a user manual may help you more, it can be downloaded ($8.95) at url: http://www.download-manual.com/shop/Zanussi-FLE1416W-User-Manual-pr-8261.html
Jan 22, 2008 | Zanussi FLE1416W Front Load Washer
Problems! zanussi zsf6120
You can check the heating element with an ohmmeter and it should read a few hundred ohms. Don't know about the thermostat but it should be inline electrically with the heating element and should ohm as a short when cold.
Nov 23, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
AL3
Possibly tge heating element,I am having the same problem .When I check during the operation it appears that the water is not heating up. Only runs the rinse programme without the error message as I assume that uses cold water only?
Nov 21, 2007 | Zanussi 24 in. DE6965 Built-in Dishwasher
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
124 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
