Question about Sewing Machines
Kemore sewing machine
I need to know how to get the bobbin back into the machine and get it threaded up to the needle the whole metal piece where bobbin fits into fell out
Hold bobbin in left hand with thread coming up and over the top of the bobbin, then drop bobbin into the holder and pull the thread through the slot and into the the 'spring' you should be able to catch the bobbin holder in your left hand just by holding the thread if done correctly. the little 'arm' on the bobbbin holder
should be pointing up - enter it to the machine with the left hand and slot the 'arm' into its position at the top- there is only place it, can go -I do hope you haven't had to wait this long to use your machine!
Posted on Apr 18, 2008
  • 106 Answers
Practicly impossible to "describe" how to do it, you need to be shown, other added problem is there are numerous different types of bobbins etc. Unless you can get someone to show you the next best option is to get hold of a copy of a user manual for your machine. Best of luck
Posted on Mar 26, 2008
6ya staff
SOURCE:
Hello, the thread from the bobbin is not getting out when the needle gets into the metal piece. Is marks stichhes on the fabric, but is does not stitch.
Make sure that when the bobbin is in place that you can pull the bobbin thread with your hand easily. If not, the bobbin may be in backwards or the bobbin thread is not properly routed. Also, make sure that the foot is down when you try to catch the bobbin thread with the needle.
Dec 07, 2014 | Sewing Machines
My needle broke and a piece of metal fell out of machine
just adjust to needle in fix to strait in needle clamp hole it operate to needle strait to hole so needle do nt break but needle is best buy qualtity
Aug 31, 2008 | Brother XR-65t Mechanical Sewing Machine
Euro Pro 9105 won't catch bobbin thread
first of all make sure you have the needle in the correct way round, flat side facing back, try a new needle, it only has to be slightly bent or blunt and it will miss stitches, the tension unit is the small piece near the takeup lever and it only has a small spring but that has nothing to do with the threading picking up, if the machine misses stitches after trying the above then you will need to retime the machine either bu a shop or by yourself, if you are sewing on fabric that collects static such as knitted fabric make sure you use an anti-static needle otherwise it will miss stitches.
Goodluck..
May 23, 2008 | Euro-Pro 9105 Computerized Sewing Machine
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
I cannot get the bobbin thread to catch and pull through the footer wen trying to thread the machine?
Make sure your bobbin is placed in correctly. Thread is counterclockwise as you place bobbin in the metal piece. Pull thread end through sliver in metal piece. Hold on to movable metal latch then lock the bobbin in place. Bobbin should not fall out but is able to rotate. Rotate the wheel on the furthest right of your Singer 1507 machine towards you to move the needle downward. The top thread should then be able to catch and pull up the bobbin thread.
Dec 02, 2010 | Singer 1507
Missed stitches noise when it happens
Firstly, turn machine off then turn back on. Change needle. Re-thread the top and bobbin threads. Make sure you have not set the machine for a sideways stitch but you have been using a single stitch foot (recipe for Disaster!). BEFORE trying to sew, wind the machine by hand through a stitch or two (take the thread out of the needle's eye first) and look closely to see if the needle is in fact hitting something. If it is, then the needle needs re-centering and you will have to take the machine for repair to get this done.
Make sure the top thread is going into the tension disks. The presser foot MUST be up while you are threading. Hold onto the thread just as it comes off the spool and when you get down to the needle give a tug to be sure the thread is seated in the tensions before threading the needle. When you insert the bobbin, be sure the thread "clicks" into the tension slot on the bobbin case. Check the Sewing Advisor to be sure you are set for the correct fabric and stitch for what you are sewing. Have you cleaned out the bobbin area? Remove the clear or smoke bobbin cover, either use the tool provided or just press down firmly and slide forwards the metal feed dog cover (feed dogs down first), lift out the light grey plastic bit that half covers the bobbin case, remove bobbin case. Use the brush and clean out all the fluff from the bobbin area. Then check the bobbin case and clean it too. You can use a piece of strong thread or UNWAXED dental floss to clean out between the tension springs (the bit where the bobbin thread 'clicks' into). Reassemble the bobbin pieces in reverse order, making sure that when you replace the metal feed dog cover you push it all the way to the back and it too will 'click' into place. Hope something in the above works for you.
Dec 23, 2009 | Husqvarna Designer I
I have the basically the same problem. i was sewing and now the thread in the needle will not pick up the bobbin thread. i would appreciate any help. I have changed the needle, bobbin, and thread several...
Check the easy stuff first:
Make sure the needle is inserted in the machine properly- a good rule of thumb is the flat side of the needle should go to the opposite side of the last thread guide. Also make sure the machine is threaded correctly.
the needle is in correctly with the flat side to the rear of the machine, make sure to thread the upper and lower portions of the machine correctly.
the needle is in the machine correctly- all the way up into the needle bar, make sure that it is threaded correctly, etc. If this all checks out ok, take the bobbin case out of the machine. There are two ears on either side of the bobbin case- turn the left one to the left and the right one to the right. Remove the silver ring, and inspect the piece of metal that the ring came off of (looks like a circle with the top cut off). You have to locate the hook which is the piece that looks like a half moon inside the big round metal piece. Locate the tip of it, turn the handwheel toward you until the needle is in the lowest position, at this point the tip of the hook should be flush with top of the left side of the cut off circle. If this is not so, your machine needs to be re-timed. If that is the case.
Aug 04, 2009 | Baby Lock Sewing Machines
Bobbin Thread Doesn't Join the Upper Thread
Have you lowered the presser foot lever? It is the lever behind the needle that makes the foot go down. Do you put the bobbin in the machine from the top of the machine or from the front? In either case, you need to make sure the bobbin thread has clicked into the tension slot in the bobbin case. The bobbin case is the part of the machine that the bobbin sits in. It will have some kind of narrow cut out with a thin metal shaped piece half covering the opening. The thread has to go down into the cut out piece and click down beside the metal piece. You will hear a faint "click" when it is in place. Very hard to describe, but easy to show someone! Write back if this is not helpful to you. Also tell us your machine model.
May 04, 2009 | Sewing Machines
Two Stitch Hang-up
youch!  how frustrating.  It sounds like there is a piece of thread caught in or around the bobbin casing.  take the whole casing out and clean with your brush.
I feel your pain, hope this helps.  If not, please come back and we'll try some other things.
Jan 18, 2009 | Brother XL-5130 Mechanical Sewing Machine
Needle won't move; something stuck/dislodged
Can you remove the bobbin? Sometimes when thread gets bunched up under the lower plate it will force the bobbin out of position. Try taking it out and cleaning any loose thread and lint from the area. Put a couple of drops of oil on the outside of the bobbin case and re-insert it. Make sure you lower the needle and pull the bobbin thread through to the top and back behind the needle before beginning to sew again.
Hope this works!
Zelma
Jan 18, 2008 | Brother XL-2230 Mechanical Sewing Machine
Sewing Machines Logo
73 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
