Question about Goodman GMS90703BXA Heater
Heat worked couple days ago. but today turned on the air and it worked but sometime it shut down and now furnace and air will not come on. check fuses in house and all are good. but have fuses outside did not try. do those have anything to do with the furnace part?
    Guru:
  • 415 Answers
It is unlikely that you have a transformer at your outdoor unit. If your furnace has an electronic control board, look for a low voltage fuse that may be blown. The low voltage fuses used now usually resemble a car fuse.
Posted on May 01, 2010
Where to look from here?
It sound like the limit switch is shutting off and not coming back in to play .
Mar 14, 2017 | Heating & Cooling
Blower stays on
It would piont to the afc not working Automatic fan control not shutting off on temp fall .
Mar 29, 2012 | Heating & Cooling
My Payne furnace is NOT producing the desired heat anymore. Any ideas?
Hello, it could be shutting down on it's high limit switch due to a dirty air filter, dirty blower wheel, weak blower motor. Usually this would cause the furnace to shut down before it reaches the desired temp.
Dec 30, 2011 | Heating & Cooling
I have a goodman furnace/air condition. The fan
start winding going bad or capisitor, either can cause high amp draw and over heat the motor
Jun 13, 2010 | Goodman CLQ36AR49 Air Conditioner
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a Rheem Gas/Electric AC unit that provides both Air and Heat. Yesterday the heat stopped working... it blows out cold air. We've had some cold temperatures lately (low 20's) but this isn't unusual...
Heat pumps provide good heat until the tempurature drops below 35-40 degrees. After that there isn't much heat to extract from the outside air and then either the gas furnace kicks in or the electric heat strip does the job of heating the air. if you have heat strips, I would check your breakers in your panel and sometimes there are a couple of breakers right on the air handler or furnace. The ones that will be for your heat strip are 220v and will be twice as wide as your normal 110v breakers . Please don't trust a visual inspection as they can look like they are in the "on" position but are indeed tripped. Turn them all they way off and then back on. If the beakers check out you may have an open cicuit in the heat strips themselves and you will need to have a qualified HVAC tech look at your furnace to repair it.
If your furnace is a "duel fuel" and uses natural or LP gas for back up heat then your ten year old rheem probably needs a good maintenance by a qualified service tech. There is a flame sensor to clean, ignitor to check (replaces the old school pilots), burners to clean flue connections to check and much more. ALL manufacturers of any heating apliance recommend yearly maintenance. Most companies offer something for around 100 bucks. I hope this helps.
Rocco
Dec 12, 2009 | Heating & Cooling
Coleman roof top a/c, is the heat controlled by thermostat
hi
on the new colman units (trane) the heat is control only from the t-stat.
i will reccomand a programble t-stat for the new unit.
thanks
Nov 02, 2009 | Coleman Mach III Air Conditioner
Goodman GMS90703BXA Heater Logo
98 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
